Schematic Gigabyte GA-B150M-SE-SI Rev 10 Schematic
BrandGigabyte Technology
ModelGA-B150M-SC-SI
Motherboard ManufacturerGigabyte Technology
Board NumberGA-B150M-SC-SI
Revision1.1
DateThursday, April 21, 2016
CPU PlatformIntel LGA1151
CPU SocketLGA1151
PCH / SouthbridgePCH (B150)
EC / KBCITE8628
Audio CodecRealtek ALC887
BIOS / SPI FlashSPI BIOS (64M)
BIOS Flash Capacity64M
RAM TypeDDR4, DDRIII
RAM ArchitectureDDR4 DIMM X 1, DDR4 DIMM X 1, DDRIII BUS
RAM Quantity / SlotsDDR4 DIMM X 1, DDR4 DIMM X 1
LAN ICRealtek 8111G
WiFi / WLAN ICRealtek 8111HS
HDMI Level Shifterrtd2168-dp-to-vga-ic/"]RTD2168 - DP to VGA - IC[/URL], RTD2168 - DP to VGA - Conn
Card Reader ICIT8892
USB Hub ICIT8892
Charging ICISL95858_856 PWM
Power IC(s)ISL95858_856 MOS_VCORE, ISL95858_856 MOS_VCCGT, RT8237_DDR_BEAD, RT8237_PCH-BEAD, NCP3933 OVER VOLTAGE
GPU TypePCI EXPRESS X16
Graphics ArchitecturePCIe-1 gen3
Document NumberCustom
The Gigabyte GA-B150M-SC-SI motherboard, revision 1.1, dated April 21, 2016, is built on the Intel LGA1151 platform with a B150 PCH. It features dual memory architecture supporting both DDR4 and DDRIII, with two DDR4 DIMM slots. The system is managed by an ITE8628 EC/KBC, and audio is handled by a Realtek ALC887 codec. Networking is provided by a Realtek 8111G LAN IC and a Realtek 8111HS WiFi/WLAN IC. The board utilizes a 64M SPI BIOS flash. Power regulation is managed by ISL95858_856 PWM and MOSFET stages for VCORE and VCCGT, alongside RT8237 and NCP3933 voltage regulation components. Display output includes an RTD2168 DP to VGA converter and HDMI support. The IT8892 controller manages card reader and USB hub functions.
A: The ITE8628 is used as the EC/KBC.
Q: What is the BIOS flash capacity?
A: The BIOS flash is a 64M SPI BIOS.
Q: What memory types does this board support?
A: The board supports both DDR4 and DDRIII memory, with two DDR4 DIMM slots.
Q: What LAN and WiFi ICs are present?
A: The LAN IC is a Realtek 8111G, and the WiFi/WLAN IC is a Realtek 8111HS.
ModelGA-B150M-SE-SI
Board NumberGA-B150M-SE-SI
Revision1.0
DateWednesday, May 25, 2016
CPU Platform[URL="https://dr-bios.com/components/cpu-platform/lga1151/"]Intel LGA1151 (Skylake)[/URL]
PCH / SouthbridgeB150
EC / KBCITE 8628
BIOS / SPI FlashSPI Dual BIOS (64M)
LAN ICRealtek RTL8111G
RAM TypeDDR4
RAM Quantity / Slots2
HDMI Level ShifterRTD2168
The Gigabyte GA-B150M-SE-SI revision 1.0 motherboard is built on the Intel LGA1151 Skylake platform with a B150 PCH. It features dual-channel DDR4 memory architecture with two DIMM slots. The board utilizes an ITE 8628 EC/KBC and a Realtek ALC887 audio codec. Networking is handled by a Realtek RTL8111G LAN IC. The SPI Dual BIOS configuration supports 64M flash. Display output includes DP to VGA conversion via the RTD2168 IC.
Q: What is the EC/KBC model used on this motherboard?
A: The EC/KBC is an ITE 8628.
A: The board uses a SPI Dual BIOS configuration with 64M capacity.
Q: What audio codec is used?
A: The audio codec is a Realtek ALC887.
Q: What LAN controller is used?
A: The LAN controller is a Realtek RTL8111G.
  • Gigabyte GA-B150M-SE-SI-Rev 10 Schematic.pdf
  • Gigabyte GA-B150M-SC-SI Rev 1.1 Schematic.pdf
