Gigabyte GA-B150M Gaming3 DDR3-DB Rev 10 Schematic
The Gigabyte GA-B150M-Gaming3 DDR3-DB revision 1.0 motherboard is built on the Intel LGA1151 Skylake platform with a B150 PCH. It features a dual BIOS architecture utilizing SPI Dual BIOS with 128M capacity. The embedded controller is an ITE 8628 LPC I/O. Audio is handled by a Realtek ALC892 codec, and networking is provided by an Intel I219V PHY. The board supports DDR3 memory across four DIMM slots. Graphics output includes DVI, HDMI, and DP-to-VGA conversion via a PTN3356 level shifter. Power management is handled by an ISL95858_856 PWM controller for VCore and VCCGT, with additional RT8120 regulators for DDR_VDDQ and PCH_VCC1_0_PCH. Thermal monitoring is managed by an NCT3933 sensor. The board includes an ASM1083 PCI bridge for legacy PCI slot support.
A: The board uses a SPI Dual BIOS architecture with 128M capacity.
Q: What EC/KBC controller is used?
A: The embedded controller is an ITE 8628 LPC I/O.
Q: What is the CPU platform and socket?
A: The board supports Intel LGA1151 Skylake processors.
Q: What audio codec is present?
A: The audio codec is a Realtek ALC892.
Q: What LAN controller is used?
A: The LAN controller is an Intel I219V.
| Model | GA-B150M-Gaming3 DDR3-DB |
| Board Number | GA-B150M-Gaming3 DDR3-DB |
| Date | Friday, February 26, 2016 |
| CPU Platform | Intel LGA1151 (Skylake) |
| PCH / Southbridge | B150 |
| EC / KBC | ITE 8628 |
| EC/KBC Package | LPC I/O ITE8628 |
| Audio Codec | Realtek ALC892 |
| BIOS / SPI Flash | SPI Dual BIOS (128M) |
| BIOS Flash Capacity | 128M |
| LAN IC | Intel I219V |
| RAM Architecture | DDR3 DIMM X 2, DDR3 DIMM X 2 |
| RAM Quantity / Slots | 4 |
| GPU Type | Intel HD Graphics |
| Graphics Architecture | Display |
| HDMI Level Shifter | PTN3356 |
| Charging IC | ISL95858_856 |
| Power IC(s) | RT8120_DDR_VDDQ, RT8120_PCH_VCC1_0_PCH |
| Thermal Sensor | NCT3933 |
| USB Hub IC | ASM1083 |
GA-B150M-GAMING3 DDR3-DB
Skylake
B150
8628
ALC892
I219V
Intel HD Graphics
DISPLAY
PTN3356
ISL95858_856
RT8120_DDR_VDDQ
NCT3933
ASM1083
Skylake
B150
8628
ALC892
I219V
Intel HD Graphics
DISPLAY
PTN3356
ISL95858_856
RT8120_DDR_VDDQ
NCT3933
ASM1083
