Gigabyte GA-B150M-DASH Rev 1.0 Schematic
The Gigabyte GA-B150M-DASH motherboard, revision 1.0, is built on the Intel LGA1151 (Skylake) platform with a B150 PCH. It features dual-channel DDR4 memory architecture with two DIMM slots. The system utilizes a single 64M BIOS configuration. The embedded controller is an ITE8628 LPC I/O chip. Audio is handled by a Realtek ALC887 codec, while networking is provided by a Realtek RTL8111EPV Gigabit LAN IC and an Intel I219 WLAN controller. The voltage regulation subsystem includes ISL95858 PWM controllers for VCCORE and VCCGT, alongside RT8120 components for VPP, PCH, and DDR rails. Display output is managed through a PTN3356 DP to VGA converter. The board also incorporates an ASM1083 PCI bridge, an IT8792E Super I/O for card reading and diagnostics, and an NTC thermal sensor map.
A: The GA-B150M-DASH uses a single 64M BIOS.
Q: What EC/KBC chip is used on this motherboard?
A: The embedded controller is an ITE8628 LPC I/O chip.
Q: What is the charging/power IC configuration?
A: The board uses ISL95858 PWM controllers for VCCORE and VCCGT, and RT8120 components for VPP, PCH, and DDR rails.
Q: What is the LAN and WLAN configuration?
A: The motherboard features a Realtek RTL8111EPV Gigabit LAN IC and an Intel I219 WLAN controller.
| Model | GA-B150M-DASH |
| Board Number | 9MB15DASH-00-10A BOM |
| Date | Tuesday, October 20, 2015 |
| CPU Platform | Intel LGA1151 (Skylake) |
| PCH / Southbridge | B150 |
| EC / KBC | ITE8628 |
| BIOS / SPI Flash | Single BIOS (64M) |
| LAN IC | Realtek RTL8111EPV |
| RAM Quantity / Slots | DDR4 DIMM X 2 |
| RAM Architecture | DDR4 CHANNEL A, DDR4 CHANNEL B |
| GPU Type | Intel LGA1151 (Skylake) |
| Graphics Architecture | DP-RGB (PTN3356) |
| Charging IC | ISL95858 PWM-IRON |
| Power IC(s) | ISL95858 MOS_VCORE-IRON, ISL95858 MOS_VCCGT-IRON, RT8120_VPP_CHOKE, RT8120_PCH-BEAD, RT8120_DDR_BEAD |
| Card Reader IC | IT8792E |
| USB Hub IC | ASM1083 PCI Bridge |
| WiFi / WLAN IC | Intel I219 |
| HDMI Level Shifter | PTN3356 - DP to VGA - IC |
| Thermal Sensor | NTC MAP |
