Gigabyte GA-B150M-D3VX-SI Schematic
The Gigabyte GA-B150M-D3VX-SI revision 1.0 motherboard is built on the Intel LGA1151 platform with a B150 PCH. It features dual DDR4 memory architecture with two DIMM slots. The system is managed by an ITE8628 EC/KBC, and audio is handled by a Realtek ALC887 codec. Networking is provided by a Realtek 8111HS LAN IC. The board utilizes a 64M SPI BIOS flash. Graphics output includes DVI and DP to VGA conversion via an RTD2168 IC. Power regulation is managed by ISL95858 PWM and MOSFET stages for Vcore and VCCGT, alongside RT8237 and NCP3933 power ICs.
A: The board uses a 64M SPI BIOS flash.
A: The EC/KBC is an ITE8628, but no explicit programming interface (ISP, JTAG, or SPI) is documented in the source.
A: The board supports DDR4 memory with two DIMM slots, configured as one DIMM per channel.
A: Graphics output includes DVI and DP to VGA conversion via an RTD2168 IC.
Reuse permitted only with source attribution.
The Gigabyte GA-B150M-D3VX-SI Rev 1.0 motherboard is built on the Intel LGA1151 platform with a B150 PCH. It features dual-channel DDR4 memory architecture with one DIMM per channel. The system is managed by an ITE8628 EC/KBC, and audio is handled by a Realtek ALC887 codec. Networking is provided by a Realtek 8111HS LAN controller. The BIOS is stored on a 64M SPI flash. Graphics output includes DVI and DP to VGA conversion via an RTD2168 IC. Power management is handled by ISL95858_856 PWM and MOSFETs for Vcore and VCCGT, along with RT8237 and NCP3933 ICs. The board also integrates an IT8892 controller for card reader and USB hub functions.
A: The board is Gigabyte GA-B150M-D3VX-SI Rev 1.0.
A: The EC/KBC is an ITE8628.
A: The BIOS is stored on a 64M SPI flash.
A: The board supports DDR4 memory with one DIMM on Channel A and one DIMM on Channel B.
| Model Name | GA-B150M-D3VX-SI |
| Date | Friday, September 18, 2015 |
| CPU Platform | LGA1151 |
| PCH / Southbridge | PCH (B150) |
| EC / KBC | ITE8628 |
| LAN IC | Realtek 8111HS |
| BIOS / SPI Flash | SPI BIOS (64M) |
| RAM Architecture | DDR4 DIMM X 1, DDR4 DIMM X 1 |
| Graphics Architecture | DVI, DP to VGA (RTD2168) |
| dGPU Chip Number | ISL95858_856 PWM, ISL95858_856 MOS_VCORE, ISL95858_856 MOS_VCCGT |
| Charging IC | RT8237_DDR_BEAD, RT8237_PCH-BEAD |
| Power IC(s) | NCP3933 OVER VOLTAGE |
| HDMI Level Shifter | RTD2168 - DP to VGA - IC |
| Board Number | GA-B150M-D3VX-SI |
| CPU Platform | Intel LGA1151 |
| RAM Architecture | DDR4 DIMM X 1 (Channel A), DDR4 DIMM X 1 (Channel B) |
| Card Reader IC | IT8892 |
| USB Hub IC | IT8892 |
LGA1151
B150
IT8628
ALC887
8111HS
ISL95858_856
NCP3933
RTD2168 - DP TO VGA - IC
GA-B150M-D3VX-SI
IT8892
IT8892
LGA1151
B150
IT8628
ALC887
8111HS
ISL95858_856
NCP3933
GA-B150M-D3VX-SI
IT8892
IT8892
