fujitsu-siemens amilo pro v2035 fic_lm7w_rev0.2 schematic
fujitsu-siemens amilo pro v2035=1=fic_lm7w_r0.2.pdf
This First International Computer, Inc. motherboard schematic, project code LM7W revision 0.2 dated August 31, 2005, is built around the Intel Celeron-M processor in a 539 BGA package paired with the VIA VN800 northbridge and VIA VT8237R southbridge. The system supports DDR2 400/533 memory via two SO-DIMM slots. The embedded controller is an M3885X in a 567 HSBGA package, with firmware stored on a Firm Ware Hub. Audio is handled by the ALC655 codec with a G1432+1410 amplifier. Networking is provided by the VT6103L PHY,
| Brand | First International Computer, Inc. |
| Motherboard Manufacturer | First International Computer, Inc. |
| Project Code | LM7W |
| Board Number | LM7W |
| Revision | 0.2 |
| Date | August 31, 2005 |
| CPU Platform | Intel Celeron-M |
| CPU Socket | 539 BGA |
| PCH / Southbridge | VIA VT8237R |
| GPU Type | [URL="https://dr-bios.com/components/graphics-models/via-vn800/"]VIA VN800[/URL] |
| EC / KBC | M3885X |
| Audio Codec | ALC655 |
| BIOS / SPI Flash | Flash ROM |
| Charging IC | Battery charger |
| RAM Type | DDR2 400/533 |
| RAM Architecture | SO-DIMM |
| LAN IC | VT6103L |
| WiFi / WLAN IC | Mini PCI |
| Card Reader IC | CB1410 |
| USB Hub IC | USB 2.0 Hub Interface |
| HDMI Level Shifter | VT1631 LVDS Transmitter |
| Thermal Sensor | Thermal Sensor |
| Power IC(s) | PMU0840 |
| Charger Architecture | Battery charger |
| Graphics Architecture | VIA VN800 |
| EC/KBC Package | 567 HSBGA |
| EC Flash / ROM | Firm Ware Hub |
| Clock Generator | ICS952906BF |
| Audio Amplifier | G1432+1410 |
| LVDS Transmitter | VT1631 |
| CardBus Controller | CB1410 |
| Fan Controller | Power Good & Fan Controller |
| Inverter Controller | Inverter Controller |
| Over Voltage Protection | OVP |
| Reset Circuit | Reset Circuit |
| PMU | PMU0840 |
| LPC KBC | M3885X |
| S-ATA | S-ATA HD / CD-ROM |
| MDC Connector | MDC Connector |
| CRT Connector | CRT Connector |
| LCD Connector | LCD Connector |
| DIP Switch & LED | DIP Switch & LED |
LM7W
LM7W
Celeron-m
539
VT8237R+
VN800
M3885X
ALC655
VT6103L
CB1410
VT1631 LVDS TRANSMITTER
PMU0840
VIA VN800
ICS952906BF
G1432+1410
Audio Amplifier
LM7W
LM7W
Celeron-m
539
VT8237R+
VN800
M3885X
ALC655
VT6103L
CB1410
PMU0840
VIA VN800
ICS952906BF
G1432+1410
Audio Amplifier
