fujitsu-siemens amilo pro v3515 fic_lm10w_rev0.7 schematic
fujitsu-siemens amilo pro v3515=1=fic_lm10w_rev0.7.pdf
The First International Computer LM10W motherboard, revision 0.7 dated February 21, 2006, is built around the VIA VN896 northbridge and VT8237A southbridge platform. It supports Yonah Celeron processors in a 539-ball BGA package and features two DDR2 SO-DIMM slots supporting 400/533 MHz memory. The system employs an M38827 EC/KBC controller, a CX20549 audio codec, and a VT6103L LAN PHY. Graphics are handled by the integrated VN896, with display output via a VT1634A LVDS transmitter and a CRT connector. Storage connectivity includes S-ATA and IDE buses, while expansion is provided through Mini PCI and Express Card slots. The board uses an ICS953009AFLF clock generator and a PMU083 power management unit. A dedicated battery charger circuit and thermal sensor are present for power and thermal management.
A: The motherboard uses an M38827 LPC KBC controller.
Q: What audio codec is implemented on this board?
A: The audio codec is a CX20549 Azalia codec.
Q: What LAN PHY is used on this motherboard?
A: The LAN PHY is a VT6103L connected via MII bus.
Q: What clock generator is used on this motherboard?
A: The clock generator is an ICS953009AFLF.
A: The motherboard supports DDR2 400/533 memory via two SO-DIMM slots.
| Brand | First International Computer, Inc. |
| Model | LM10W |
| Motherboard Manufacturer | First International Computer, Inc. Portable Computer Group |
| Project Code | LM10W |
| Board Number | LM10W |
| Revision | 0.7 |
| Date | Feb 21, 2006 |
| CPU Platform | VIA VN896 + VT8237A |
| PCH / Southbridge | VT8237A |
| EC / KBC | M38827 |
| Audio Codec | CX20549 |
| LAN IC | VT6103L |
| Charging IC | Battery charger |
| RAM Type | DDR2 400/533 |
| WiFi / WLAN IC | Mini PCI (Wireless LAN) |
| Graphics Architecture | VN896 |
| HDMI Level Shifter | VT1634A |
| Card Reader IC | EXPRESS CARD |
| Power IC(s) | PMU083 |
| Thermal Sensor | Thermal Sensor |
| Audio Amplifier | G1432+1410 |
| Clock Generator | ICS953009AFLF |
| Document Number | LM10W < VIA VN896 + VT8237A > |
