fujitsu-siemens amilo pro v2030 fic_lm7r_rev0.1 schematic
fujitsu-siemens amilo pro v2030=1=fic_lm7r_rev0.1.pdf
The First International Computer LM7R motherboard schematic, revision 0.1 dated March 1, 2005, is built around the VIA VN800 northbridge and VT8237R southbridge, supporting a Banias Celeron CPU. Memory architecture consists of two DDR2 400/533 SO-DIMM slots. The system integrates an M3885X EC/KBC, an ALC655 audio codec, a VT6103L LAN PHY, and a GMT1420 audio amplifier. Graphics output is handled by the VIA VN800 with a VT1631 LVDS transmitter for LCD panels. Expansion includes a MiniPCI slot, a TI4510R CardBus controller, and a USB 2.0 hub interface. Power management is managed by a PMU084 controller with a dedicated battery charger circuit. Clock generation is provided by an ICS952906BF clock generator.
A: The EC/KBC is an M3885X.
A: The audio codec is an ALC655.
A: The LAN IC is a VT6103L PHY.
A: The motherboard supports DDR2 400/533 memory via two SO-DIMM slots.
| Brand | First International Computer, Inc. |
| Project Code | LM7R |
| Board Number | LM7R |
| Revision | 0.1 |
| Date | March 1, 2005 |
| CPU Platform | Banias Celeron |
| PCH / Southbridge | VIA VT8237R |
| GPU Type | VIA VN800 |
| EC / KBC | M3885X |
| Audio Codec | ALC655 |
| LAN IC | VT6103L |
| RAM Type | DDR2 400/533 |
| Card Reader IC | TI4510R |
| WiFi / WLAN IC | MiniPCI |
| HDMI Level Shifter | VT1631 |
| Charging IC | Battery charger |
| Power IC(s) | PMU084 |
| Thermal Sensor | Thermal Sensor |
| Audio Amplifier | GMT1420 |
| Clock Generator | ICS952906BF |
| USB Hub IC | USB 2.0 Hub Interface |
LM7R
LM7R
Banias
VT8237R+
VN800
M3885X
ALC655
VT6103L
TI4510R
MiniPCI
VT1631
PMU084
GMT1420
ICS952906BF
LM7R
LM7R
Banias
VT8237R+
VN800
M3885X
ALC655
VT6103L
TI4510R
MiniPCI
VT1631
PMU084
GMT1420
ICS952906BF
