Schematic Fujitsu Siemens Amilo Pro V8010 Quanta EF6 Rev 1A Schematic
BrandQuanta Computer Inc.
Project CodeEF6
DateMonday, January 03, 2005
CPU PlatformIntel Dothan Processor
CPU Socket609 PGA
FSBFSB533/400MHz
PCH / SouthbridgeICH6-M
GMCHAlviso-GM
EC / KBCPC97551
Audio CodecALC655
BIOS / SPI FlashISA BIOS
Charging ICMAX1907 ( CPU_CORE )
RAM TypeDDR II SODIMM
RAM ArchitectureDual Channel DDR2
RAM Quantity / Slots2
USB Hub ICGMT1428
Clock GeneratorICS954226
Super I/OSIOPC87383
Audio AmplifierAMCODEC
Thermal SensorCPU Thermal Sensor
Battery ChargerBATTERY CHARGER
The Quanta EF6 project is a motherboard designed for the Intel Dothan processor in a 609 PGA socket, supporting FSB533/400MHz. The platform is built around the Alviso-GM GMCH and ICH6-M southbridge, with dual-channel DDR2 SODIMM memory across two slots. System management is handled by the PC97551 EC/KBC, while the ISA BIOS provides firmware storage. Power regulation is managed by a multi-rail system including the MAX1907 for CPU core, MAX1845 for 1.5V and VCCP, MAX1999 for 3VPCU and 5VPCU, SC4215 for 2.5V, and SC486IMLTRT for 1.8SUS and 0.9V. Networking is provided by both RTL8100CL (10/100M) and RTL8110SB (1G) controllers. The clocking solution is the ICS954226 clock generator, and expansion is supported by the TI PCI7411 card reader controller and ICS954206. Audio is handled by the ALC655 codec with an AMCODEC amplifier, and modem functionality is provided by Conexant DAA components.
A: The EC/KBC is the PC97551.
Q: What type of BIOS storage is used?
A: The motherboard uses ISA BIOS for firmware storage.
  • Fujitsu Siemens Amilo Pro V8010 Quanta EF6 Rev 1A.pdf
