dell latitude e5410 e5510 fonseca14 09276-sc uma -1 0319-1 09276-sc rx02 0310 1
This Wistron Fonseca 14" UMA motherboard, project code Fonseca UMAX02, board number DF3-1448.4GN01.0 revision 1.0, is built on the Intel Ibex Peak-M platform with a Mobile Arrandale CPU in an rPGA988A socket and an Intel PCH HM55 southbridge. The graphics architecture is UMA. The system uses DDR III memory across two DIMM slots configured as Channel A and Channel B. The embedded controller is a MEC 5045 with an ECE 5028 SIO Expander. The main BIOS is stored on a 64Mb SPI flash, while the LOM flash is 8Mb. The charging architecture is managed by a TI BQ24745 RHDR charger. Power regulation is handled by ADP3211, TPS51125, TPS51218, TPS51116, ISL62883, MAX17036, and RT9018. The audio codec is an IDT92HD81 Azalia CODEC. Networking is provided by a BCM5761E LAN IC and a WLAN module. The card reader IC is an R5U242, and the USB hub IC is a TPS2231 MRGPR. Thermal monitoring uses an EMC4022 sensor, and the HDMI level shifter is a MAX4885EETG.
A: The board number is DF3-1448.4GN01.0, revision 1.0, under project code Fonseca UMAX02.
| Model | Fonseca 14" UMA |
| Project Code | Fonseca UMAX02 |
| Board Number | DF3-1448.4GN01.0 |
| Date | Friday, March 19, 2010 |
| CPU Platform | Intel Ibex Peak-M / Mobile Arrandale |
| CPU Socket | rPGA988A |
| PCH / Southbridge | Intel PCH HM55 |
| GPU Type | UMA |
| EC / KBC | MEC 5045 |
| EC/KBC Package | ECE 5028 SIO Expander |
| Audio Codec | IDT92HD81 Azalia CODEC |
| BIOS / SPI Flash | SPI FLASH 64Mb |
| BIOS Flash Capacity | 64Mb |
| EC Flash / ROM | LOM FLASH 8Mb |
| Charging IC | TI BQ24745 |
| Charger Architecture | BQ24745 RHDR Charger |
| Power IC(s) | ADP3211, TPS51125, TPS51218, TPS51116, ISL62883, MAX17036, RT9018 |
| RAM Type | DDR III |
| RAM Architecture | DDR III DIMM1, DIMM2 Channel A, Channel B |
| LAN IC | BCM5761E |
| WiFi / WLAN IC | WLAN Module |
| Card Reader IC | R5U242 |
| USB Hub IC | TPS2231 MRGPR |
| Thermal Sensor | EMC4022 |
| HDMI Level Shifter | MAX4885EETG |
UMAX02
DF3-1448.4GN01.0
Arrandale
Ibex Peak-M
HM55
UMA
MEC5045
IDT92HD81 AZALIA CODEC
BQ24745
ADP3211
ISL62883
MAX17036
RT9018
TPS51116
TPS51125
TPS51218
BCM5761E
R5U242
TPS2231 MRGPR
EMC4022
MAX4885EETG
UMAX02
DF3-1448.4GN01.0
Arrandale
Ibex Peak-M
HM55
UMA
MEC5045
BQ24745
ADP3211
ISL62883
MAX17036
RT9018
TPS51116
TPS51125
TPS51218
BCM5761E
R5U242
TPS2231 MRGPR
EMC4022
MAX4885EETG
