dell latitude e5410 e5510 fonseca14 09226-sb uma x01 1103-1 1
The Wistron Fonseca UMA motherboard, revision X01, dated November 3, 2009, is built around the Intel Ibex Peak-M platform with a Mobile Arrandale CPU in an rPGA988A socket and an Intel PCH HM55 southbridge. The integrated graphics architecture is UMA, driven by CPU_GFXCORE. System memory consists of DDR III across two DIMM slots, Channel A and Channel B. The embedded controller is a MEC 5045 with LPC interface, supported by an 8Mb EC flash. The main BIOS is stored on a 64Mb SPI flash. Power management is handled by a TI BQ24745 battery charger and a suite of DC/DC converters including ADP3211, TPS51218, TPS51116, TPS51125, ISL62883, MAX17036, RT9035, and RT9018. Audio is provided by an IDT92HD81 Azalia CODEC. Connectivity includes a BCM5761E LAN IC, a WLAN module, and a MAX4885EETG+ HDMI level shifter. The board also features a R5U242 card reader and a TPS2231MRGPR USB hub controller. The document number is 91.4GN01.001 with a schematic number of 91.4EQ01.001.
Q: What is the EC/K
| Model | Fonseca UMA |
| Project Code | Fonseca UMA |
| Board Number | 48.?????.0 |
| Revision | X01 |
| Date | Tuesday, November 03, 2009 |
| CPU Platform | Intel Ibex Peak-M |
| CPU Socket | rPGA988A |
| CPU Model | Mobile Arrandale |
| PCH / Southbridge | Intel PCH HM55 |
| GPU Type | UMA |
| Graphics Architecture | CPU_GFXCORE |
| EC / KBC | MEC 5045 |
| EC/KBC Package | LPC |
| Audio Codec | IDT92HD81 Azalia CODEC |
| BIOS / SPI Flash | SPI FLASH 64Mb |
| BIOS Flash Capacity | 64Mb |
| EC Flash / ROM | FLASH 8Mb |
| Charging IC | TI BQ24745 |
| Charger Architecture | BATTERY CHARGER |
| Power IC(s) | ADP3211, TPS51218, TPS51116, TPS51125, ISL62883, MAX17036, RT9035, RT9018 |
| RAM Type | DDR III |
| RAM Quantity / Slots | DIMM1, DIMM2 |
| Card Reader IC | R5U242 |
| USB Hub IC | TPS2231MRGPR |
| LAN IC | BCM5761E |
| WiFi / WLAN IC | WLAN Module |
| HDMI Level Shifter | MAX4885EETG+ |
| Document Number | 91.4GN01.001 |
| PCB Number | 48.?????.0 |
| Schematic Number | 91.4EQ01.001 |
Q: What is the EC/K
48.?????.0
Ibex Peak-M
Mobile Arrandale
HM55
CPU_GFXCORE
MEC5045
IDT92HD81 AZALIA CODEC
BQ24745
ADP3211
ISL62883
MAX17036
RT9018
RT9035
TPS51116
TPS51125
TPS51218
R5U242
TPS2231MRGPR
BCM5761E
MAX4885EETG
48.?????.0
Ibex Peak-M
Mobile Arrandale
HM55
CPU_GFXCORE
MEC5045
BQ24745
ADP3211
ISL62883
MAX17036
RT9018
RT9035
TPS51116
TPS51125
TPS51218
R5U242
TPS2231MRGPR
BCM5761E
MAX4885EETG
