dell latitude e5410 e5510 fonseca15_uma_09276 - sb 09226 - sb revx01 schematic
dell latitude e5410 e5510=1=fonseca15_uma_09276 - sb 09226 - sb revx01.pdf
The Wistron Fonseca UMA motherboard, revision X01, is built around the Intel Ibex Peak-M platform with an rPGA988A socket supporting Mobile Arrandale processors and an Intel PCH HM55 southbridge. The integrated UMA graphics architecture relies on the CPU_GFXCORE. System memory consists of DDR III across two DIMM slots configured as Channel A and Channel B. The embedded controller is a MEC 5045 communicating via LPC, with an 8Mb EC flash ROM. The main BIOS is stored on a 64Mb SPI flash. Power management is handled by a TI BQ24745 battery charger, with system DC/DC conversion provided by ADP3211, TPS51125, TPS51218, TPS51116, ISL62883, MAX17036, and RT9035. Audio is managed by an IDT92HD81 Azalia codec, networking by a BCM5761E LAN IC, and card reading by an O2Micro R5U242 controller. The board also includes a TPS2231 USB hub controller and a MAX4885EETG+ HDMI level shifter.
A: The main BIOS is stored on a 64Mb SPI flash. The EC firmware is stored on a separate 8Mb flash ROM.
Q: What EC/KBC is used and is it programmable?
A: The embedded controller is a MEC 5045, which communicates via
| Model | Fonseca UMA |
| Project Code | Fonseca UMA |
| Board Number | 48.?????.0 |
| Revision | X01 |
| Date | Tuesday, November 03, 2009 |
| CPU Platform | Intel Ibex Peak-M |
| CPU Socket | rPGA988A |
| CPU Model | Mobile Arrandale |
| PCH / Southbridge | Intel PCH HM55 |
| GPU Type | UMA |
| Graphics Architecture | CPU_GFXCORE |
| EC / KBC | MEC 5045 |
| EC/KBC Programmable | LPC |
| Audio Codec | IDT92HD81 Azalia |
| BIOS / SPI Flash | SPI FLASH 64Mb |
| BIOS Flash Capacity | 64Mb |
| EC Flash / ROM | FLASH 8Mb |
| Charging IC | TI BQ24745 |
| Charger Architecture | BATTERY CHARGER BQ24745 |
| Power IC(s) | ADP3211, TPS51125, TPS51218, TPS51116, ISL62883, MAX17036, RT9035 |
| RAM Type | DDR III |
| RAM Quantity / Slots | DIMM1, DIMM2 |
| LAN IC | BCM5761E |
| Card Reader IC | O2Micro R5U242 |
| USB Hub IC | TPS2231 |
| HDMI Level Shifter | MAX4885EETG+ |
| Thermal Sensor | EMC4022 |
| WiFi / WLAN IC | WLAN Module |
| Document Number | 91.4GN01.001 |
48.?????.0
Ibex Peak-M
Mobile Arrandale
HM55
CPU_GFXCORE
MEC5045
IDT92HD81 AZALIA
BQ24745
ADP3211
ISL62883
MAX17036
RT9035
TPS51116
TPS51125
TPS51218
BCM5761E
O2MICRO R5U242
TPS2231
MAX4885EETG
EMC4022
48.?????.0
Ibex Peak-M
Mobile Arrandale
HM55
CPU_GFXCORE
MEC5045
IDT92HD81 AZALIA
BQ24745
ADP3211
ISL62883
MAX17036
RT9035
TPS51116
TPS51125
TPS51218
BCM5761E
O2MICRO R5U242
TPS2231
MAX4885EETG
EMC4022
