dell latitude e5410 e5510 wistron df3_fonseca 14 dis 09281-sb_revx01 schematic
df3_fonseca 14 dis 09281-sb_revx01.pdf
The Wistron Fonseca 14.1" DIS motherboard, project code 91.4GQ01.001 with board number 91.4GQ01.0SB revision 09281 - SB, is built around the Intel Ibex Peak-M PCH supporting an Intel Mobile CPU Arrandale in an rPGA988A socket. Graphics are handled by an ATI M92-LP GPU with 512MB of DDR3 VRAM. The system uses DDR III memory across two DIMM slots configured as Channel A and Channel B. The embedded controller is an ECE 1077 with an ECE 5045 LPC package, and the BIOS is stored on a 64Mb SPI flash. An additional 8Mb LOM flash is present for the EC. The charging architecture is managed by a TI BQ24745 battery charger, and the power delivery subsystem includes ISL62883, TPS51116, TPS51511, TPS51125, TPS51218, and RT9035 regulators. The audio codec is an IDT92HD81 Azalia, networking is provided by a BCM5761E LAN IC, and the HDMI interface uses a MAX4885EETG+ level shifter.
A: The BIOS is stored on a 64Mb SPI flash.
A: The embedded controller is an ECE 1077 with an ECE 5045 LPC package.
A: The charging IC is a TI BQ24745.
| Model | Fonseca 14.1" DIS |
| Project Code | 91.4GQ01.001 |
| Board Number | 91.4GQ01.0SB |
| Revision | 09281 - SB |
| Date | Monday, November 02, 2009 |
| CPU Platform | Intel Ibex Peak-M |
| CPU Model | Intel Mobile CPU Arrandale |
| CPU Socket | rPGA988A |
| PCH / Southbridge | Intel Ibex Peak-M |
| GPU Type | ATI M92-LP |
| Graphics Architecture | DDR3 800MHz 64Mx16bx4 (512MB) VRAM |
| EC / KBC | ECE 1077 |
| EC/KBC Package | ECE 5045 LPC |
| Audio Codec | IDT92HD81 Azalia CODEC |
| BIOS / SPI Flash | SPI FLASH 64Mb |
| BIOS Flash Capacity | 64Mb |
| EC Flash / ROM | LOM FLASH 8Mb |
| Charging IC | TI BQ24745 |
| Charger Architecture | BATTERY CHARGER BQ24745 |
| Power IC(s) | ISL62883, TPS51116, TPS51511, TPS51125, TPS51218, RT9035 |
| RAM Type | DDR III |
| RAM Quantity / Slots | DIMM1, DIMM2 |
| Card Reader IC | R5U242 |
| LAN IC | BCM5761E |
| WiFi / WLAN IC | WLAN Switch |
| HDMI Level Shifter | MAX4885EETG+ |
91.4GQ01.001
91.4GQ01.0SB
Ibex Peak-M
M92-LP
ECE1077
IDT92HD81 AZALIA CODEC
BQ24745
ISL62883
RT9035
TPS51116
TPS51125
TPS51218
TPS51511
R5U242
BCM5761E
MAX4885EETG
91.4GQ01.001
91.4GQ01.0SB
Ibex Peak-M
M92-LP
ECE1077
BQ24745
ISL62883
RT9035
TPS51116
TPS51125
TPS51218
TPS51511
R5U242
BCM5761E
MAX4885EETG
