acer husk-petra dis 20120906 rev-4m husk nvidia 4m n13p-gl csd 1
This Wistron Husk/Petra-4M motherboard, documented under project code 91.4TU01.001 and document number A31103 revision A3, is designed for the Ivy Bridge CPU platform paired with an Intel PCH HM70/77 Panther Point southbridge. The discrete graphics solution utilizes an Nvidia N13P-GL1 GPU in a 16-lane, 128-bit, 29x29mm package. System management is handled by an NPCE885 EC/KBC, while audio is provided by an ALC271X codec. The BIOS is stored on an 8MB SPI flash ROM. Power management is distributed across multiple ICs including the BQ24727 charger, ISL95836HRTZ, RT8223MGQW, TPS51218DSCR, RT8207LGQW, RT9025-25ZSP, and ISL62882CHRTZ. Memory configuration supports DDRIII 1600/1333 across two Channel A slots. Networking and card reader functions are integrated into the RTL8411 controller.
A: The motherboard uses an NPCE885 EC/KBC.
A: The BIOS is stored on an 8MB SPI flash ROM.
Q: What is the discrete GPU model on this board?
A: The discrete GPU is an Nvidia N13P-GL1 in a 16-lane, 128-bit, 29x29mm package.
A: The charging IC is a BQ24727.
| Project Code | 91.4TU01.001 |
| Board Number | -4M |
| Document Number | A31103 |
| Revision | A3 |
| Date | Thursday, September 06, 2012 |
| CPU Platform | Ivy Bridge |
| PCH / Southbridge | Intel PCH HM70/77 Panther Point |
| GPU Type | Nvidia N13P-GL1 |
| Graphics Architecture | 16 lane/128bit/29x29mm |
| EC / KBC | NPCE885 |
| Audio Codec | ALC271X |
| BIOS / SPI Flash | SPI Flash ROM 8MB |
| Charging IC | BQ24727 |
| Power IC(s) | ISL95836HRTZ, RT8223MGQW, TPS51218DSCR, RT8207LGQW, RT9025-25ZSP, ISL62882CHRTZ |
| RAM Type | DDRIII 1600/1333 |
| RAM Architecture | Channel A Slot 0, Channel A Slot 1 |
| LAN IC | RTL8411 |
| Card Reader IC | RTL8411 |
91.4TU01.001
4M
Ivy Bridge
HM70
N13P-GL1
NPCE885
ALC271X
BQ24727
ISL62882CHRTZ
ISL95836HRTZ
RT8207LGQW
RT8223MGQW
RT9025-25ZSP
TPS51218DSCR
RTL8411
RTL8411
91.4TU01.001
4M
Ivy Bridge
HM70
N13P-GL1
NPCE885
ALC271X
BQ24727
ISL62882CHRTZ
ISL95836HRTZ
RT8207LGQW
RT8223MGQW
RT9025-25ZSP
TPS51218DSCR
RTL8411
RTL8411
