Acer V5-531 Wistron Petra UMA MB 11324-1 48.4vm02.011 Schematic
The Wistron Petra Uma-1 motherboard (Project Code 91.4VM01.001, Board Number 48.4VM02.001, Revision -1) is an Ivy Bridge platform design dated February 22, 2012. It utilizes a Sandy Bridge PCH HM70/77 Panther Point southbridge and features UMA graphics architecture. The system is powered by a BQ24727 charger IC and multiple DC/DC converters including ISL95836HRTZ, RT8207LGQW, RT9025-25ZSP, G978, TPS51218DSCR, and RT8223MGQW. Memory configuration consists of two DDRIII slots supporting 1600/1333 MHz. The embedded controller is an NPCE885P, and the audio codec is an ALC271X. The BIOS is stored on an 8MB SPI Flash ROM. Additional onboard ICs include an NCT7718W thermal sensor, an RTL8411 card reader and LAN controller, and HDMI level shifting support.
A: The BIOS is stored on an 8MB SPI Flash ROM.
A: The embedded controller is an NPCE885P.
A: The charging IC is a BQ24727.
A: The motherboard supports DDRIII memory at 1600/1333 MHz across two slots (Slot 0 and Slot 1).
| Model | Petra Uma-1 |
| Project Code | 91.4VM01.001 |
| Board Number | 48.4VM02.001 |
| Revision | -1 |
| Date | Wednesday, February 22, 2012 |
| CPU Platform | Ivy Bridge |
| PCH / Southbridge | Sandy Bridge PCH: HM70/77 Panther Point |
| GPU Type | UMA |
| EC / KBC | NPCE885P |
| Audio Codec | ALC271X |
| BIOS / SPI Flash | SPI Flash ROM 8MB |
| Charging IC | BQ24727 |
| Power IC(s) | ISL95836HRTZ, RT8207LGQW, RT9025-25ZSP, G978, TPS51218DSCR, RT8223MGQW |
| RAM Architecture | DDRIII 1600/1333, DDRIII 1333/1600 Channel A |
| Thermal Sensor | NCT7718W |
| Card Reader IC | RTL8411 |
| LAN IC | RTL8411 |
| HDMI Level Shifter | HDMI |
91.4VM01.001
48.4VM02.001
Ivy Bridge
HM70
NPCE885P
ALC271X
BQ24727
ISL95836HRTZ
RT8207LGQW
RT8223MGQW
RT9025-25ZSP
TPS51218DSCR
NCT7718W
RTL8411
RTL8411
91.4VM01.001
48.4VM02.001
Ivy Bridge
HM70
NPCE885P
ALC271X
BQ24727
ISL95836HRTZ
RT8207LGQW
RT8223MGQW
RT9025-25ZSP
TPS51218DSCR
NCT7718W
RTL8411
RTL8411
