acer aspire e1 v1 v3-531 571 compal la-7912p rev b
This Compal LA-7912P motherboard, revision 0.2, is designed for the Q5WV1/Q5WS1 model and is built around the Intel Sandy/Ivy Bridge processor platform with DDRIII memory and a Panther Point-M PCH. The discrete graphics solution is provided by an Nvidia N13P GS/GL GPU. System management is handled by an ENE KB930/KB9012 EC/KBC, while audio is managed by an ALC271X/281X codec. The board features a single SPI ROM for BIOS storage and utilizes two 204-pin DDRIII SO-DIMM slots for memory expansion. Integrated connectivity includes a BCM57785 controller for LAN and card reader functions, and a Fresco FL1009 USB 3.0 hub controller.
A: The motherboard uses an ENE KB930/KB9012 EC/KBC.
Q: What is the discrete GPU on this motherboard?
A: The discrete GPU is an Nvidia N13P GS/GL.
A: The audio codec is an ALC271X/281X.
Q: What is the memory configuration for this motherboard?
A: The motherboard supports DDRIII memory via two 204-pin SO-DIMM slots.
| Model | Q5WV1/Q5WS1 |
| Project Code | SCHEMATIC,MB A7912 4019ID60B |
| Board Number | LA-7912P |
| Revision | 0.2 |
| Date | 2011-12-24 |
| CPU Platform | Intel Sandy/Ivy Bridge Processor with DDRIII + Panther Point PCH |
| PCH / Southbridge | Panther Point-M |
| GPU Type | Nvidia N13P GS/GL |
| EC / KBC | ENE KB930/KB9012 |
| Audio Codec | ALC271X/281X |
| BIOS / SPI Flash | SPI ROM x1 |
| Charging IC | BCM57785 |
| RAM Architecture | 204pin DDRIII-SO-DIMM X2 |
| LAN IC | BCM57785 |
| Card Reader IC | BCM57785 |
| USB Hub IC | Fresco FL1009 |
