acer aspire v5-471 wistron husk_petra_rev-4m schematic
acer aspire v5-471=1=wistron husk_petra_rev-4m.pdf
This Wistron Husk/Petra-4M motherboard, project code 91.4TU01.001, revision A3, is an Ivy Bridge platform designed for DIS IVB Touch configurations. The board features an Intel CPU 17W/GT2 paired with an Intel PCH HM70/77 Panther Point southbridge. Graphics are handled by an Nvidia N13P-GL1 GPU in a 16 lane/128bit/29x29mm package. The system BIOS is stored on an 8MB SPI Flash ROM. Embedded controller functions are managed by an NPCE885 KBC. Audio is provided by an ALC271X codec, while networking includes an NCT 7718W LAN controller and Mini-Card with 802.11a/b/g wireless. The charging architecture utilizes a BQ24727 charger IC with DCBATOUT input. Power regulation is handled by multiple ICs including RT8223MGQW, ISL95836HRTZ, TPS51218DSCR, RT8207LGQW, RT9025-25ZSP, ISL62882CHRTZ, and G978. Memory support includes two DDRIII slots supporting 1333/1600 MHz. A RTL8411B card reader IC is also present.
A: The motherboard uses an 8MB SPI Flash ROM for BIOS storage.
A: The embedded controller is an NPCE885 KBC.
Q: What is the charging IC and architecture on this motherboard?
A: The charging IC is a BQ24727, with the architecture using DCBATOUT as the input.
A: The discrete GPU is an Nvidia N13P-GL1 in a 16 lane/128bit/29x29mm package.
| Model | Husk/Petra-4M |
| Project Code | 91.4TU01.001 |
| Board Number | -4M |
| Revision | A3 |
| Date | Thursday, September 06, 2012 |
| CPU Platform | Ivy Bridge |
| CPU Model | Intel CPU 17W/GT2 |
| PCH / Southbridge | Intel PCH HM70/77 Panther Point |
| GPU Type | Nvidia N13P-GL1 |
| Graphics Architecture | 16 lane/128bit/29x29mm |
| EC / KBC | NPCE885 |
| Audio Codec | ALC271X |
| BIOS / SPI Flash | SPI Flash ROM 8MB |
| Charging IC | BQ24727 |
| Charger Architecture | INPUTS DCBATOUT |
| Power IC(s) | RT8223MGQW, ISL95836HRTZ, TPS51218DSCR, RT8207LGQW, RT9025-25ZSP, ISL62882CHRTZ, G978 |
| RAM Architecture | DDRIII 1600/1333 Channel A Slot 0, DDRIII 1333/1600 Channel A Slot 1 |
| Card Reader IC | RTL8411B |
| LAN IC | NCT 7718W |
| WiFi / WLAN IC | Mini-Card and BT 802.11a/b/g |
91.4TU01.001
4M
Ivy Bridge
Intel CPU 17W/GT2
HM70
N13P-GL1
NPCE885
ALC271X
BQ24727
ISL62882CHRTZ
ISL95836HRTZ
RT8207LGQW
RT8223MGQW
RT9025-25ZSP
TPS51218DSCR
RTL8411B
NCT7718W
91.4TU01.001
4M
Ivy Bridge
Intel CPU 17W/GT2
HM70
N13P-GL1
NPCE885
ALC271X
BQ24727
ISL62882CHRTZ
ISL95836HRTZ
RT8207LGQW
RT8223MGQW
RT9025-25ZSP
TPS51218DSCR
RTL8411B
NCT7718W
