toshiba satellite l650 l650d bl10g-6050a2332301-mb-x01 schematic
toshiba satellite l650 l650d=1=bl10g-6050a2332301-mb-x01.pdf
This Inventec BL10 motherboard, project code BL10GCSA3661 revision X01 dated 2010.03.18, is built on the Auburndale CPU platform using Socket-rPGA989. The system is managed by a WINB_NPCE781LA0DX embedded controller. Audio is handled by a Conex_CX20671 codec. The BIOS is stored on an 8MB SPI flash device. System charging is controlled by a MAX_MAX17435ETG+ in a TQFN-24 package. Networking is provided by an Atheros_AR8151 Gigabit LAN controller. A REA_RTS5159 5-in-1 card reader IC is present. Thermal monitoring is performed by a GMT_G686LT11U sensor in a SOT23-5P package.
A: The EC/KBC is a WINB_NPCE781LA0DX.
A: The BIOS is stored on an 8MB SPI flash device.
A: The charging IC is a MAX_MAX17435ETG+ in a TQFN-24 package.
Q: What LAN controller is present?
A: The LAN controller is an Atheros_AR8151 Gigabit Ethernet controller.
| Model | BL10 |
| Motherboard Manufacturer | Inventec |
| Project Code | BL10GCSA3661 |
| Board Number | BL10GCSA3661 |
| Revision | X01 |
| Date | 2010.03.18 |
| CPU Platform | Auburndale (Socket-rPGA989) |
| EC / KBC | WINB_NPCE781LA0DX |
| Audio Codec | Conex_CX20671 |
| BIOS / SPI Flash | SPI Flash 8MB |
| Charging IC | MAX_MAX17435ETG+_TQFN_24 |
| LAN IC | Atheros_AR8151 (Giga Lan) |
| Card Reader IC | REA_RTS5159 |
| Thermal Sensor | GMT_G686LT11U_SOT23_5P |
