toshiba satellite l600-p205d quanta te3_rev1a schematic
toshiba satellite l600-p205d=1=quanta te3_rev1a.pdf
This Quanta TE3NB4 motherboard is built on the AMD S1g4 platform with an SB820 southbridge. Graphics are handled by an RX881/RS880MN/RS880M GPU connected via C_A_LINK (X4). The system uses DDRIII-SODIMM memory at 1066 MHz across two slots. The embedded controller is a WPCE775, and the audio codec is a CX20583. The BIOS is stored on a SPI Flash ROM. Networking is provided by an AR8152M 10/100 LAN controller. The clock generator is an ICS9LPRS476AKLF. A TSLG8SP628VTR card reader controller and an RTM880N-795 WiFi module are also present. The PCB stack-up consists of six layers: TOP, GND1, IN1, IN2, VCC, and BOT.
A: The embedded controller is a WPCE775.
Q: What type of BIOS flash is used?
A: The BIOS is stored on a SPI Flash ROM.
A: The board supports DDRIII-SODIMM memory at 1066 MHz across two slots.
Q: What is the GPU configuration?
A: The graphics subsystem uses an RX881/RS880MN/RS880M GPU connected via C_A_LINK (X4).
| Project Code | TE3NB4 |
| Document Number | 5544332211DDCCBBAA |
| Revision | 1A |
| Date | Tuesday, March 02, 2010 |
| CPU Platform | AMD S1g4 |
| PCH / Southbridge | SB820 |
| GPU Type | RX881/RS880MN/RS880M |
| Graphics Architecture | C_A_LINK (X4) |
| EC / KBC | WPCE775 |
| Audio Codec | CX20583 |
| BIOS / SPI Flash | SPI Flash ROM |
| LAN IC | AR8152M (10/100) |
| RAM Type | DDRIII-SODIMM |
| RAM Architecture | DDR III 1066 MHZ |
| Card Reader IC | TSLG8SP628VTR |
| WiFi / WLAN IC | RTM880N-795 |
| Clock Generator | ICS9LPRS476AKLF |
TE3NB4
S1G4
SB820
RS880M
RS880MN
RX881
C_A_LINK (X4)
WPCE775
CX20583
AR8152M
TSLG8SP628VTR
RTM880N-795
ICS9LPRS476AKLF
TE3NB4
S1G4
SB820
RS880M
RS880MN
RX881
C_A_LINK (X4)
WPCE775
CX20583
AR8152M
TSLG8SP628VTR
RTM880N-795
ICS9LPRS476AKLF
