toshiba satellite l600_l600d quanta_te3_rev1a schematic
toshiba satellite l600_l600d=1=quanta_te3_rev1a.pdf
The Quanta TE3NB4 motherboard is an AMD S1g4 platform design, documented under revision 1A dated March 2, 2010. The system architecture is built around the SB820 southbridge and supports RX881, RS880MN, or RS880M graphics with a side port DDR3 frame buffer. Memory configuration consists of two DDRIII-SODIMM slots operating at 1066 MHz. The embedded controller is a WPCE775, and the audio subsystem is handled by a CX20583 Azalia Audio Codec. The BIOS is stored on a SPI flash ROM. Networking is provided by an AR8152M 10/100 LAN controller. The board also features a TSLG8SP628VTR card reader controller, an ICS9LPRS476AKLF clock generator, and an RTM880N-795 thermal sensor.
A: The embedded controller is a WPCE775.
Q: What is the BIOS storage type?
A: The BIOS is stored on a SPI flash ROM.
Q: What graphics configurations are supported?
A: The board supports RX881, RS880MN, or RS880M graphics with a side port DDR3 frame buffer.
A: The board supports two DDRIII-SODIMM slots operating at 1066 MHz.
| Project Code | TE3NB4 |
| Document Number | 5544332211DDCCBBAASize |
| Revision | 1A |
| Date | Tuesday, March 02, 2010 |
| CPU Platform | AMD S1g4 |
| PCH / Southbridge | SB820 |
| GPU Type | RX881/RS880MN/RS880M |
| Graphics Architecture | Side port FRAME BUFFER DDR3 |
| EC / KBC | WPCE775 |
| Audio Codec | CX20583 Azalia Audio Codec |
| BIOS / SPI Flash | Flash ROM SPI |
| RAM Type | DDRIII-SODIMM |
| RAM Architecture | DDR III 1066 MHZ |
| LAN IC | AR8152M (10/100) |
| Card Reader IC | TSLG8SP628VTR |
| Clock Generator | ICS9LPRS476AKLF |
| Thermal Sensor | RTM880N-795 |
TE3NB4
S1G4
SB820
RS880M
RS880MN
RX881
WPCE775
CX20583 AZALIA AUDIO CODEC
AR8152M
TSLG8SP628VTR
ICS9LPRS476AKLF
RTM880N-795
TE3NB4
S1G4
SB820
RS880M
RS880MN
RX881
WPCE775
AR8152M
TSLG8SP628VTR
ICS9LPRS476AKLF
RTM880N-795
