toshiba satellite c640d 6050a2357601-mb-ax1 ct10ad
The Inventec Calcutta 10AD (Board Number CSA3445, Revision A3) is an AMD Danube (Champlain) platform motherboard using an RS880M GPU and SB820M Southbridge. The CPU socket is PGA S1G4. System memory consists of two DDR3 SODIMM slots. The embedded controller is a WINBOND KBC, and the audio codec is a CX20671. Networking is provided by an Atheros WLAN IC and a 10/100 AR8152 LAN IC. The charging architecture is a System Charger controlled by a MAX_MAX17435ETG+ TQFN-24 IC. The BIOS is stored on a SPI EEROM. A card reader IC is also present on the board.
A: The board number is CSA3445, revision A3.
Q: What CPU platform and socket does this motherboard use?
A: It uses the AMD Danube (Champlain) platform with a PGA S1G4 socket.
Q: What is the charging IC used on this motherboard?
A: The charging IC is a MAX_MAX17435ETG+ in a TQFN-24 package.
Q: What type of BIOS flash is used?
A: The BIOS is stored on a SPI EEROM.
| Brand | INVENTEC |
| Model | Calcutta 10AD |
| Motherboard Manufacturer | INVENTEC |
| Project Code | Calcutta 10AD |
| Board Number | CSA3445 |
| Revision | A3 |
| Date | 11-Jan-2010 |
| Document Number | 1310A2357601 |
| CPU Platform | AMD Danube (Champlain) |
| CPU Socket | PGA S1G4 |
| PCH / Southbridge | SB820M |
| GPU Type | RS880M |
| EC / KBC | WINBOND |
| Audio Codec | CX20671 |
| BIOS / SPI Flash | SPI EEROM |
| Charging IC | MAX_MAX17435ETG+_TQFN_24 |
| Charger Architecture | System Charger |
| LAN IC | 10/100 AR8152 |
| WiFi / WLAN IC | Atheros |
| RAM Type | DDR3 |
| RAM Architecture | DDR3_SODIMM |
| Card Reader IC | CARD READER |
