Schematic toshiba c640d 6050a2414501-mb-x01 abg ct10ab schematic
BrandInventec
ModelCalcutta10AB\ABG CT10AB
Motherboard ManufacturerInventec
Project CodeCalcutta10AB
Board NumberCT10AB
RevisionX01 Build
Date31-Aug-2010
CPU PlatformAMD Brazos Platform
CPU ModelAMD Ontario
PCH / SouthbridgeHudson M1
GPU TypeIntegrated (AMD APU)
EC / KBCNPCE781L
Audio CodecCX20671
BIOS / SPI FlashSPI EEROM
Charging ICTI_BQ24725RGR
RAM TypeDDR3_SODIMM
RAM Quantity / Slots2 (DDR3_SODIMM0, DDR3_SODIMM1)
LAN IC10/100 AR8151
WiFi / WLAN ICAtheros
This Inventec Calcutta10AB CT10AB motherboard, revision X01 Build dated 31-Aug-2010, is built on the AMD Brazos platform featuring an AMD Ontario APU with integrated graphics and a Hudson M1 Fusion Controller Hub (FCH). The system memory architecture consists of two DDR3 SODIMM slots. The embedded controller is an NPCE781L, and the audio codec is a Conexant CX20671. The BIOS is stored on an SPI EEROM. Power management is handled by a TI BQ24725RGR charging IC. Networking is provided by an Atheros AR8151 10/100 LAN controller and an Atheros wireless LAN module.
Q: What is the EC/KBC model used on this motherboard?
A: The embedded controller is an NPCE781L.
A: The charging IC is a TI BQ24725RGR in a QFN-20 package.
Q: What type of memory does this motherboard use?
A: This motherboard uses DDR3 SODIMM memory in two slots.
Q: What is the audio codec on this board?
A: The audio codec is a Conexant CX20671.
  • Toshiba_C640D=_6050A2414501-MB-X01_ABG_CT10AB_DR-BIOS.COM.zip
