toshiba c640d 6050a2414501-mb-x01 abg ct10ab
This Inventec Calcutta10AB CT10AB motherboard, revision X01 Build dated 31-Aug-2010, is built on the AMD Brazos platform featuring an AMD Ontario APU with integrated graphics and a Hudson M1 Fusion Controller Hub (FCH). The system memory architecture consists of two DDR3 SODIMM slots. The embedded controller is an NPCE781L, and the audio codec is a Conexant CX20671. The BIOS is stored on an SPI EEROM. Power management is handled by a TI BQ24725RGR charging IC. Networking is provided by an Atheros AR8151 10/100 LAN controller and an Atheros wireless LAN module.
Q: What is the EC/KBC model used on this motherboard?
A: The embedded controller is an NPCE781L.
A: The charging IC is a TI BQ24725RGR in a QFN-20 package.
Q: What type of memory does this motherboard use?
A: This motherboard uses DDR3 SODIMM memory in two slots.
Q: What is the audio codec on this board?
A: The audio codec is a Conexant CX20671.
| Model | Calcutta10AB\ABG CT10AB |
| Motherboard Manufacturer | Inventec |
| Project Code | Calcutta10AB |
| Board Number | CT10AB |
| Revision | X01 Build |
| Date | 31-Aug-2010 |
| CPU Platform | AMD Brazos Platform |
| CPU Model | AMD Ontario |
| PCH / Southbridge | Hudson M1 |
| GPU Type | Integrated (AMD APU) |
| EC / KBC | NPCE781L |
| Audio Codec | CX20671 |
| BIOS / SPI Flash | SPI EEROM |
| Charging IC | TI_BQ24725RGR |
| RAM Type | DDR3_SODIMM |
| RAM Quantity / Slots | 2 (DDR3_SODIMM0, DDR3_SODIMM1) |
| LAN IC | 10/100 AR8151 |
| WiFi / WLAN IC | Atheros |
