Schematic toshiba satellite c640d 6050a2357601-mb-ax1 ct10ad schematic
BrandINVENTEC
ModelCalcutta 10AD
Motherboard ManufacturerINVENTEC
Project CodeCalcutta 10AD
Board NumberCSA3445
RevisionA3
Date11-Jan-2010
Document Number1310A2357601
CPU PlatformAMD Danube (Champlain)
CPU SocketPGA S1G4
PCH / SouthbridgeSB820M
GPU TypeRS880M
EC / KBCWINBOND
Audio CodecCX20671
BIOS / SPI FlashSPI EEROM
Charging ICMAX_MAX17435ETG+_TQFN_24
Charger ArchitectureSystem Charger
LAN IC10/100 AR8152
WiFi / WLAN ICAtheros
RAM TypeDDR3
RAM ArchitectureDDR3_SODIMM
RAM Quantity / Slots2
Card Reader ICCARD READER
The Inventec Calcutta 10AD (Board Number CSA3445, Revision A3) is an AMD Danube (Champlain) platform motherboard using an RS880M GPU and SB820M Southbridge. The CPU socket is PGA S1G4. System memory consists of two DDR3 SODIMM slots. The embedded controller is a WINBOND KBC, and the audio codec is a CX20671. Networking is provided by an Atheros WLAN IC and a 10/100 AR8152 LAN IC. The charging architecture is a System Charger controlled by a MAX_MAX17435ETG+ TQFN-24 IC. The BIOS is stored on a SPI EEROM. A card reader IC is also present on the board.
A: The board number is CSA3445, revision A3.
Q: What CPU platform and socket does this motherboard use?
A: It uses the AMD Danube (Champlain) platform with a PGA S1G4 socket.
Q: What is the charging IC used on this motherboard?
A: The charging IC is a MAX_MAX17435ETG+ in a TQFN-24 package.
Q: What type of BIOS flash is used?
A: The BIOS is stored on a SPI EEROM.
  • Toshiba_Satellite_C640D=_6050A2357601-MB-AX1_CT10AD_DR-BIOS.COM.zip
