Schematic Surface book 2 Shield TS STB-DV Schematic
BrandIntel
CPU PlatformIntel KBL U42
EC / KBCMK22FN512VDC12
Audio CodecRealtek ALC3269-CG
BIOS / SPI FlashW25Q128FVPIQ
BIOS Flash Exact ModelW25Q128FVPIQ
BIOS Flash Capacity16MB
EC Flash / ROMW25X40CLUXIG
Charging ICBQ25700RSNR
RAM TypeLPDDR3
RAM Architecture2x32 @ 1866MHz
RAM Quantity / Slots4GB/8GB
LAN ICMarvell 8897
WiFi / WLAN ICMarvell 8897
Card Reader ICGL9755
USB Hub ICTS3A27518ERTWR
Speaker AmplifierALC1304
TPMNPCT650ABBWX
Temperature SensorSN1608035
Accelerometer + GyroBosch BMI160
E-compass (Magnetometer)MEMSIC MMC3530KJ
ALS/Proximity SensorIntersil ISL29033
Authentication ICATECC508A
Hall Effect Sensor (Laptop)ROHM BU52058GWZ-E2
Hall Effect Sensor (Canvas)ROHM BU52058GWZ-E2
Battery18Wh
This Intel KBL U42 platform motherboard features an Intel processor with LPDDR3 memory down configuration of 4GB or 8GB in 2x32 architecture at 1866MHz. The system BIOS is stored on a W25Q128FVPIQ 16MB SPI flash, while the EC/KBC firmware resides on a separate W25X40CLUXIG EEPROM. The embedded controller is an MK22FN512VDC12 microcontroller. Audio is handled by a Realtek ALC3269-CG codec paired with an ALC1304 speaker amplifier. Charging is managed by a BQ25700RSNR battery charge controller supporting an 18Wh battery. Wireless connectivity is provided by a Marvell 8897 module supporting 802.11/b/g/n/ac and Bluetooth 4.0. The board includes a GL9755 card reader, a TS3A27518ERTWR USB hub, and an NPCT650ABBWX TPM. Sensor aggregation includes a Bosch BMI160 accelerometer and gyroscope, a MEMSIC MMC3530KJ magnetometer, an Intersil ISL29033 ambient light and proximity sensor, and two ROHM BU52058GWZ-E2 Hall effect sensors. Authentication is handled by an ATECC508A cryptographic co-processor.
A: The BIOS SPI flash is a W25Q128FVPIQ with 16MB capacity.
A: Yes, the EC/KBC is an MK22FN512VDC12 microcontroller with a separate W25X40CLUXIG EEPROM for SAM reflash image backup.
Q: What is the memory configuration on this motherboard?
A: The board uses LPDDR3 memory down configuration with 2x32 architecture at 1866MHz, available in 4GB or 8GB capacity.
A: The battery charge controller is a BQ25700RSNR supporting an 18Wh battery.
  • Surface book 2 Shield TS STB-DV Schematic.pdf
