Schematic Surface Book 2 Gauntlet TS-ZTB Schematic
CPU PlatformIntel KBL U42/U22
EC / KBCMK22FN512VDC12A
Audio CodecRealtek ALC3269-CG
BIOS / SPI Flashw25q128fvpiq-u3702/"]W25Q128FVPIQ U3702[/URL]
BIOS Flash Exact ModelW25Q128FVPIQ
BIOS Flash Capacity16MB
EC Flash / ROMW25X40CLUXIG
Charging ICBQ25700RSNR
RAM TypeLPDDR3
RAM Architecture2 x32 @1866MHz
RAM Quantity / Slots4GB/8GB
LAN ICMarvell 8897
WiFi / WLAN ICMarvell 8897
Card Reader ICNPCT650ABBWX
Thermal SensorSN1608035
Power IC(s)TS3A27518ERTWR
dGPU Chip NumberG15W ([URL="https://dr-bios.com/components/discrete-gpus/bga1168/"]BGA1168)[/URL]
Graphics ArchitectureIntel Processor KBL U42/U22 eDP
This motherboard is built on the Intel KBL U42/U22 platform with LPDDR3 memory configured as 2 x32 at 1866MHz supporting 4GB or 8GB. The system BIOS is stored on a 16MB W25Q128FVPIQ SPI flash at U3702. The embedded controller is an MK22FN512VDC12A microcontroller with a separate W25X40CLUXIG SPI flash for EC firmware backup. Audio is handled by a Realtek ALC3269-CG codec. Power management includes a BQ25700RSNR battery charge controller. Wireless connectivity is provided by a Marvell 8897 module supporting WLAN 802.11 a/b/g/n/ac and Bluetooth 4.0. The discrete GPU is a G15W in BGA1168 package. Additional components include an NPCT650ABBWX TPM, SN1608035 thermal sensor, and TS3A27518ERTWR power switch.
A: The BIOS SPI flash is a W25Q128FVPIQ at U3702, 16MB capacity.
A: Yes, the EC is an MK22FN512VDC12A microcontroller with a separate W25X40CLUXIG SPI flash for SAM reflash image backup.
A: The battery charge controller is a BQ25700RSNR.
Q: What memory configuration does this motherboard support?
A: The board uses LPDDR3 memory in a 2 x32 configuration at 1866MHz, supporting 4GB or 8GB total.
  • Surface Book 2 Gauntlet TS-ZTB Schematic.pdf
