Schematic inventec e-book 6050a2354501 epd pre-ws-build rev x01 2009.12.28 schematic
BrandINVENTEC
Motherboard ManufacturerINVENTEC CORPORATION
Project CodeX01
Board Number6050A2354501
RevisionA3
Date29-Dec-2009
CPU PlatformOMAP362X
Document NumberE_BOOKCSA3252
EC / KBCTI_TPS65921ZQZ_PBGA_120
EC/KBC PackagePBGA_120
Audio CodecTLV320AIC3111
Charging ICBQ24073
Power IC(s)TI_TPS65921ZQZ_PBGA_120
RAM TypeLPDDR
RAM Architecture2Gb
WiFi / WLAN ICTWL1271
Card Reader ICTWL1271
USB Hub ICTUSB1210
Thermal SensorBH1620FVC
CPLDXC2C64A
This Inventec reference design, documented under board number 6050A2354501 revision A3, is built around the OMAP362X application processor platform. The system integrates a TI_TPS65921ZQZ_PBGA_120 device serving as both the EC/KBC and primary power management IC, supplemented by a TPS6518x PMIC. Memory architecture consists of LPDDR with 2Gb capacity. Audio is handled by a TLV320AIC3111 codec, while battery charging is managed by a BQ24073 charger IC. Wireless connectivity is provided by a TWL1271 module, and USB connectivity is supported by a TUSB1210 USB PHY. The design includes an XC2C64A CPLD for glue logic, and environmental sensing is covered by BH1620FVC and MMA7660FC sensors, with an additional KXTF9-4100 accelerometer. The document date is 29-Dec-2009.
Q: What is the main power management and EC/KBC IC on this board?
A: The TI_TPS65921ZQZ_PBGA_120 in a PBGA_120 package serves as both the EC/KBC and primary PMIC.
A: The audio codec is a TLV320AIC3111.
Q: What is the charging IC for the battery?
A: The battery charging IC is a BQ24073.
Q: What type of memory does this board use?
A: The board uses LPDDR memory with a 2Gb capacity.
  • Inventec=E-BOOK_6050A2354501_EPD_Pre-WS-Build_Rev_X01_2009.12.28_DR-BIOS.COM.zip
