MSI MS-9149 Rev 100 0A 0B 10A 20A Schematic
The MSI MS-9149 REV 00A is a server/workstation motherboard based on the Intel Canterwood-ES MCH and ICH-HR chipset, supporting a uPGA478 Intel Pentium 4 processor with 533/800MHz FSB. Memory architecture consists of four DDR DIMM slots supporting up to 4GB of DDR 400/333/266 ECC memory in dual-channel configuration. Integrated graphics is provided by an ATI RAGE XL with 8MB memory. The board features dual Intel Gigabit Ethernet controllers, an Intel 82547EI on the CSA bus and an Intel 82541EI on the PCI bus. Storage is handled by a PROMISE/PDC20378 SATA controller supporting two Serial ATA ports and one IDE RAID connector, alongside the ICH-HR's integrated IDE and SATA. System management includes an NS/87431M Mini BMC and an ADT7463 hardware monitor. The VRM is implemented with an Intersil 6556B controller.
A: The board number is MS-9149 REV 00A.
Q: What EC/KBC and Super I/O controller is used?
A: The board uses an NS/PC87366 Super I/O controller.
Q: What is the charging and power delivery architecture?
A: The VRM is implemented with an Intersil 6556B controller (VRM 10).
Q: What LAN controllers are present on this motherboard?
A: The board features an Intel 82547EI LAN (CSA) and an Intel 82541EI LAN (PCI).
Q: What SATA controller is used for RAID functionality?
A: The board uses a PROMISE/PDC20378 SATA controller supporting 2 Serial ATA ports and 1 IDE RAID connector.
The MSI MS-9149 REV 00A motherboard is built on the Intel Canterwood-ES and ICH-HR chipset, supporting an Intel Pentium 4 478-pin processor with a 533/800MHz FSB. Memory architecture consists of four DIMM slots supporting up to 4GB of DDR 400/333/266 ECC memory in dual-channel configuration. Integrated graphics is provided by an ATI RAGE XL with 8MB memory. The board features dual Intel Gigabit Ethernet LAN controllers, specifically the 82547EI and 82541EI, along with an Intel 82540EM wireless module. Storage is handled by a PROMISE/PDC20378 SATA controller supporting two Serial ATA ports and one IDE RAID connector. System monitoring and audio codec functions are managed by the ADT7463 H/W Monitor. The EC/KBC is an NS/PC87366 Super I/O controller. Power delivery is managed by an Intersil 6556B VRM controller.
Q: What is
The MSI MS-9149 Rev A motherboard, manufactured by Micro-Star Int'l Co., Ltd. in October 2003, is built around the Intel Canterwood-ES MCH and ICH-HR chipset. It supports Intel Pentium 4 Northwood/Prescott 478-pin processors with 533/800MHz FSB. The board features four DDR DIMM slots supporting up to 4GB of DDR 400/333/266 ECC memory in dual-channel configuration. Integrated graphics is provided by an ATI RAGE XL with 8MB memory. Networking is handled by dual Intel Gigabit Ethernet controllers: the 82547GI (CSA interface) and the 82541GI (PCI interface). Storage connectivity includes a PROMISE/PDC20378 SATA controller supporting two Serial ATA ports and one IDE RAID connector, plus two additional IDE channels (ATA 100/66/33) from the ICH-HR. The system monitoring and audio codec functions are managed by an ADT7463 hardware monitor. The LPC Super I/O is an NS/PC87366, and a mini BMC NS/87431M is present for baseboard management. The clock generator is a CK409, and the VRM controller is an Intersil 6556B. The board is a 4-layer ATX form factor measuring 12" x 9.6".
A: The board number is MS-9149, revision A.
Q: What CPU socket and platform does this board support?
A: It supports Intel Pentium 4 478-pin processors (Northwood/Prescott) with 533/800MHz FSB, using a uPGA478 socket.
Q: What memory configuration is supported?
A: Four DDR DIMM slots supporting up to 4GB of DDR 400/333/266 ECC memory in dual-channel configuration.
Q: What LAN controllers are used?
A: Dual Intel Gigabit Ethernet controllers: the 82547GI (CSA interface) and the
The MS-9149 REV 00A is a Micro-Star International motherboard built around the Intel Canterwood-ES MCH and ICH-HR southbridge chipset, supporting a uPGA478 Pentium 4 Northwood/Prescott processor with 533/800MHz FSB. Memory architecture consists of four DDR DIMM slots supporting up to 4GB of DDR 400/333/266 ECC memory in dual-channel configuration. Integrated graphics is provided by an ATI RAGE XL PCI32 VGA controller with 8MB dedicated memory. Networking is handled by dual Intel Gigabit Ethernet controllers: the 82547GI connected via CSA and the 82541GI on the PCI bus. Storage expansion includes a Promise PDC20378 SATA controller supporting two Serial ATA ports and one IDE RAID connector, alongside the ICH-HR's native IDE and SATA interfaces. The system is supervised by an ADT7463 hardware monitor, an NS/87431M Mini BMC, and an NS/PC87366 Super I/O. Clock generation is managed by a CK409 clock synthesizer, and CPU power regulation is handled by an Intersil 6556B VRM controller.
Q: What chipset does this motherboard use?
A: This motherboard uses the Intel Canterwood-ES MCH paired with the ICH-HR southbridge.
A: This motherboard supports DDR 400/333/266 ECC memory in a dual-channel configuration across four DIMM slots, with a maximum capacity of 4GB.
Q: What LAN controllers are used on this motherboard?
A: This motherboard uses two Intel Gigabit Ethernet controllers: the 82547GI connected via the CSA interface and the 82541GI on the PCI bus.
Q: What SATA controller is present on this board?
A: This motherboard uses a Promise PDC20378 SATA controller, providing two Serial ATA ports and one IDE RAID connector.
The MSI MS-9149 Rev 100 is a server/workstation motherboard designed for the Intel P4 Northwood/Prescott 478-pin processor with a 533/800MHz FSB, utilizing the Intel Canterwood-ES MCH and ICH-HR chipset. Memory support includes up to 4GB of DDR 400/333/266 ECC across four DIMMs in a dual-channel architecture. Integrated graphics is provided by an ATI RAGE XL with 8MB of dedicated memory. Networking is handled by dual Intel Gigabit Ethernet controllers, including the 82547GI (CSA) and 82541GI (PCI32). Storage expansion includes a Promise PDC20378 SATA controller supporting two Serial ATA ports and one IDE RAID connector. The board features an NS/PC87366 Super I/O, an ADT7463 hardware monitor, and an NS/87431M Mini BMC for management. The clocking solution is a CK409 generator, and the VRM is controlled by an Intersil 6556B.
A: The board number is MS-9149, revision 100.
Q: What CPU socket and platform does this motherboard support?
A: It supports the Intel P4 Northwood/Prescott 478-pin processor (uPGA478 socket) with a 533/800MHz FSB.
Q: What type of memory and maximum capacity is supported?
A: It supports up to 4GB of DDR 400/333/266 ECC memory across 4 DIMMs in a dual-channel configuration.
Q: What are the onboard LAN controllers?
A: The motherboard features two Intel Gigabit Ethernet controllers: the 82547GI (CSA) and the 82541GI (PCI32).
Q: What SATA controller is used and what are its capabilities?
A: The board uses a Promise PDC20378 SATA controller, which provides 2 Serial ATA ports and 1 IDE RAID connector.
This MSI MS-9149 REV 100 motherboard is built on the Intel Canterwood-ES / ICH-HR chipset, supporting Intel P4 Northwood/Prescott 478-pin processors with 533/800MHz FSB. Memory architecture consists of 4 DDR DIMM slots supporting up to 4GB of DDR 400/333/266 ECC memory in dual-channel configuration. Integrated graphics is provided by an ATI RAGE XL with 8MB dedicated memory. Networking is handled by dual Intel Gigabit Ethernet controllers, specifically the INTEL 82547GI LAN-CSA and INTEL 82541GI LAN. The system features a NS/PC87366 Super I/O for legacy connectivity and an ADT7463 hardware monitor for thermal management. Storage expansion includes a PROMISE/PDC20378 SATA controller supporting 2 Serial ATA ports and 1 IDE RAID connector. The board is an ATX form factor measuring 12" by 9.6" with 4 layers.
Q: What is the board number for this MSI motherboard?
A: The board number is MS-9149 REV 100.
A: It supports the uPGA478 socket for Intel P4 Northwood/Prescott processors with 533/800MHz FSB.
A: It supports 4 DDR DIMM modules with up to 4GB of DDR 400/333/266 ECC memory in dual-channel mode.
Q: What LAN controllers are used on this board?
A: Dual Intel Gigabit Ethernet controllers are used: INTEL 82547GI LAN-CSA and INTEL 82541GI LAN.
Q: What Super I/O and hardware monitor chips are present?
A: The Super I/O is a NS/PC87366, and the hardware monitor is an ADT7463.
This MSI MS-9149 Rev 100 motherboard, designed by Micro-Star Int'l Co., Ltd. and dated December 30, 2003, is built around the Intel Canterwood-ES MCH and ICH-HR chipset. It supports Intel P4 Northwood/Prescott 478-pin processors with 533/800MHz FSB via a uPGA478 socket. Memory architecture consists of four DDR DIMM slots supporting up to 4GB of DDR 400/333/266 ECC memory in dual-channel configuration. Integrated graphics is provided by an ATI RAGE XL with 8MB dedicated memory. Networking is handled by dual Intel Gigabit Ethernet controllers: the 82547GI LAN-CSA and the 82541GI LAN. The system includes a PROMISE/PDC20378 SATA controller for Serial ATA and IDE RAID support. The NS/87431M Mini BMC serves as the embedded controller, while the NS/PC87366 Super I/O manages legacy I/O. The VRM is controlled by an Intersil 6556B, and clock generation is managed by a CK409 synthesizer.
A: It supports up to 4GB of DDR 400/333/266 ECC memory across 4 DIMM slots in dual-channel architecture.
Q: What embedded controller is used on this board?
A: The embedded controller is the NS/87431M Mini BMC.
Q: What LAN controllers are present?
A: Dual Intel Gigabit Ethernet controllers are used: the 82547GI LAN-CSA and the 82541GI LAN.
The MSI MS-7149 (MS-7149N1) motherboard, documented under MS-714910A revision 1.3 dated July 12, 2005, is built around the Intel 915GV (Grantsdale GV) northbridge paired with the Intel ICH6 southbridge, supporting an Intel Prescott LGA775 processor. Graphics are integrated within the 915GV chipset. System memory consists of two DDR2 DIMM slots supporting a maximum of 2GB. The BIOS is stored on a Firmware Hub (FWH) EEPROM. The embedded controller and Super I/O functions are handled by the SMSC DME1737. Audio is provided by an ADI 1981B AC97 codec, and networking is via a Broadcom BCM5788 PCI LAN controller. Power regulation is managed by an Intersil HIP6565ACV 3-phase PWM controller with HIP6602B and HIP6601B phase drivers. The clock generator is a CY28410OXC (ICS954101). Expansion includes two PCI 2.3 slots and a riser card slot. Storage connectivity includes one primary IDE channel and two SATA ports.
Q: What BIOS IC type is used on this MS-7149 motherboard?
A: The BIOS is stored on a Firmware Hub (FWH) EEPROM.
Q: What EC/KBC chip is used on this motherboard?
A: The SMSC DME1737 serves as both the Super I/O and the embedded controller
This MSI MS-9149 revision 200 motherboard, designed by Micro-Star Int'l Co., Ltd. in August 2005, is built on the Intel Canterwood-ES / ICH-HR chipset platform. It supports Intel P4 Northwood/Prescott 478-pin processors with 533/800MHz FSB via a uPGA478 socket. Memory architecture consists of four DDR DIMM slots supporting up to 4GB of DDR 400/333/266 ECC memory in dual-channel configuration. Integrated graphics is provided by an ATI RAGE XL with 8MB dedicated memory. Networking is handled by dual Intel Gigabit Ethernet controllers: the 82547GI LAN-CSA and the 82541GI LAN. Storage expansion includes a PROMISE/PDC20378 SATA controller supporting two Serial ATA ports and one IDE RAID connector, alongside the ICH-HR's native IDE and SATA interfaces. The system management subsystem features an NS/87431M Mini BMC and an ADT7463 hardware monitor. Clock generation is managed by a CK409 synthesizer, and power delivery is regulated by an Intersil 6556B VR controller.
A: The board number is MS-9149, revision 200.
A: It supports Intel P4 Northwood/Prescott 478-pin processors with 533/800MHz FSB using a uPGA478 socket.
A: It supports up to 4GB of DDR 400/333/266 ECC memory across four DIMM slots in dual-channel configuration.
Q: What is the integrated graphics solution on this board?
A: The integrated graphics is an ATI RAGE XL with 8MB of dedicated memory.
The MSI MS-9149 Rev 200 motherboard is an ATX form factor (12"*9.6") design from Micro-Star Int'l Co., Ltd., dated 2004/02/21. It supports Intel P4 Northwood/Prescott 478-pin processors with 533/800MHz FSB on a uPGA478 socket. The chipset consists of the Canterwood-ES MCH paired with the ICH-HR southbridge. Memory architecture is dual-channel DDR 400/333/266 ECC across four DIMM slots, supporting up to 4GB. Integrated graphics is provided by an ATI RAGE XL with 8MB dedicated memory. The system utilizes an Intersil 6556B VRM for processor core power delivery. Networking is handled by dual Intel Gigabit Ethernet controllers: the 82547GI LAN-CSA and the 82541GI LAN. Storage expansion includes a PROMISE/PDC20378 SATA controller supporting two Serial ATA ports and one IDE RAID connector, alongside two IDE channels (ATA 100/66/33). The LPC Super I/O is an NS/PC87366, and hardware monitoring is managed by an ADT7463 H/W Monitor. A Mini BMC (NS/87431M) is present for baseboard management. The clocking solution is provided by a CK409 clock generator. The firmware is stored on a Firmware Hub (FWH) device.
The MSI MS-9149 Rev 200 motherboard, manufactured by Micro-Star Int'l Co., Ltd., is built on the Intel Canterwood-ES / ICH-HR chipset platform supporting a uPGA478 Pentium 4 processor with 533/800MHz FSB. Memory architecture consists of 4 DIMMs supporting up to 4GB of DDR 400/333/266 ECC in dual-channel configuration. Integrated graphics is provided by an ATI RAGE XL with 8MB dedicated memory. The board features dual Intel Gigabit Ethernet LAN controllers, specifically the 82547GI LAN-CSA and 82541GI LAN. The Super I/O controller is an NS/PC87366, and hardware monitoring is handled by an ADT7463 H/W Monitor. A PROMISE/PDC20378 SATA controller provides Serial ATA and IDE RAID support. The system also includes an NS/87431M Mini BMC for management functions. Power delivery is managed by a VRM 10 based on the Intersil 6556B controller. The clock generator is a CK409, and the board is a 4-layer ATX form factor measuring 12" by 9.6".
A: The board number is MS-9149 with revision 200.
Q: What CPU socket and chipset does this motherboard use?
A: It uses a uPGA478 socket for Pentium 4 processors and the Intel Canterwood-ES / ICH-HR chipset.
Q: What type of memory and how many slots are supported?
A: It supports 4 DIMMs of DDR 400/333/266 ECC memory in dual-channel configuration, with a maximum of 4GB.
Q: What LAN controllers are present on this board?
A: The board features dual Intel Gigabit Ethernet LAN controllers: the 82547GI LAN-CSA and the 82541GI LAN.
Q: What is the Super I/O and BMC configuration?
A: The Super I/O is an NS/PC87366, and the BMC is an NS/87431
| Brand | MSI |
| Model | MS-9149 |
| Motherboard Manufacturer | Micro-Star Int'l Co., Ltd. |
| Board Number | MS-9149 REV 00A |
| Revision | 00A |
| Date | August 5, 2003 |
| CPU Platform | Intel Pentium 4 478 |
| CPU Socket | uPGA478 |
| PCH / Southbridge | Intel ICH-HR |
| GPU Type | ATI RAGE XL |
| Graphics Architecture | ATI VGA |
| EC / KBC | NS/PC87366 |
| Audio Codec | ADT7463 H/W Monitor |
| Charging IC | Intersil 6556B |
| Power IC(s) | VRM 10 - [URL="https://dr-bios.com/components/power-ic/6556b/"]Intersil 6556B[/URL] |
| RAM Type | DDR 400/333/266 ECC |
| RAM Quantity / Slots | 4 DIMMs |
| LAN IC | Intel 82547EI / Intel 82541EI |
| WiFi / WLAN IC | Intel 82540EM |
| Card Reader IC | PROMISE/PDC20378 |
| USB Hub IC | ICH-HR |
| Thermal Sensor | ADT7463 |
| Super I/O | NS/PC87366 |
| BMC | [URL="https://dr-bios.com/components/bmc/ns-87431m/"]NS/87431M Mini BMC[/URL] |
| Clock Generator | CK409 |
| SATA Controller | PROMISE/PDC20378 |
| Brand | MSI |
| Model | MS-9149 |
| Revision | 00A |
| CPU Platform | Intel Pentium 4 478 CPU |
| PCH / Southbridge | ICH-HR |
| HDMI Level Shifter | ADT7463 H/W Monitor |
| Storage Controller | PROMISE/PDC20378 |
| PMIC | Intersil 6556B |
| USB-C Controller | ICH-HR |
| HDMI Controller | ADT7463 H/W Monitor |
| MagSafe Controller | ICH-HR |
| Wireless Module | Intel 82540EM |
| Audio Amplifier | ADT7463 H/W Monitor |
| SD Card Controller | PROMISE/PDC20378 |
| IMU | ADT7463 H/W Monitor |
| IPD | ICH-HR |
| Backlight Driver | ADT7463 H/W Monitor |
| Keyboard Backlight | ICH-HR |
| VR Controller | Intersil 6556B |
| CIO Redriver | ICH-HR |
| Clover Controller | ICH-HR |
Q: What is
| Brand | MSI |
| Model | MS-9149 |
| Board Number | MS-9149 |
| Revision | A |
| Date | October 17, 2003 |
| Audio Codec | ADT7463 |
| LAN IC | Intel 82547GI, Intel 82541GI |
| BMC | NS/87431M |
| VRM Controller | Intersil 6556B |
| Form Factor | ATX (12" x 9.6") |
| Layers | 4 |
| Brand | MSI |
| Motherboard Manufacturer | MICRO-STAR INT'L CO., LTD. |
| Revision | 00A |
| Date | 22, 2003 |
| CPU Platform | Canterwood-ES + ICH-HR |
| Graphics Architecture | PCI32 VGA |
| LAN IC | INTEL 82547GI, INTEL 82541GI |
| Hardware Monitor | ADT7463 |
| Layer Count | 4 Layer |
| Brand | MSI |
| Model | MS-9149 |
| Revision | 100 |
| Date | Tuesday, December 30, 2003 |
| CPU Platform | Intel P4 Northwood/Prescott 478-pin Processor with 533/800MHZ FSB |
| GPU Type | [URL="https://dr-bios.com/components/graphics-models/ati-rage-xl/"]ATI RAGE XL with 8M Memory[/URL] |
| LAN IC | INTEL 82540EM/82541GI |
| LAN IC | INTEL 82547GI |
| Mini BMC | NS/87431M |
| RAM Quantity / Slots | 4 DIMMs. Max. 4GB |
| Form Factor | 4 Layer ATX Form Factor(12"*9.6") |
| Brand | MSI |
| Board Number | MS-9149 REV 100 |
| LAN IC | [URL="https://dr-bios.com/components/lan-ic/82547gi/"]INTEL 82547GI LAN-CSA[/URL] |
| LAN IC | [URL="https://dr-bios.com/components/lan-ic/82541gi/"]INTEL 82541GI LAN[/URL] |
| Thermal Sensor | ADT7463 H/W Monitor |
| Card Reader IC | [URL="https://dr-bios.com/components/card-reader-ic/promise-pdc20378/"]PROMISE/PDC20378 SATA Controller[/URL] |
| WiFi / WLAN IC | INTEL 82540EM/82541GI |
| Brand | MSI |
| Model | MS-9149 |
| Revision | 100 |
| EC / KBC | NS/87431M Mini BMC |
| LAN IC | [URL="https://dr-bios.com/components/lan-ic/82547gi/"]Intel 82547GI LAN-CSA[/URL] / [URL="https://dr-bios.com/components/lan-ic/82541gi/"]Intel 82541GI LAN[/URL] |
| WiFi / WLAN IC | Intel 82540EM/82541GI |
| Form Factor | 4 Layer ATX (12"*9.6") |
| Brand | MSI (Micro-Star International) |
| Model | MS-7149 |
| Board Number | MS-7149N1 |
| Document Number | MS-714910A |
| Revision | 1.3 |
| Date | Tuesday, July 12, 2005 |
| CPU Platform | Intel LGA775 |
| CPU Model | Intel Prescott |
| Chipset / Northbridge | Intel 915GV (Grantsdale GV) |
| Southbridge | Intel ICH6 |
| GPU Type | Integrated (Intel 915GV) |
| Graphics Architecture | Intel Grantsdale GV |
| EC / KBC | SMSC DME1737 |
| Audio Codec | ADI 1981B (AD1981B) |
| BIOS / SPI Flash | FWH EEPROM |
| LAN IC | BCM5788 |
| RAM Type | DDR2 |
| RAM Quantity / Slots | 2 (Max 2GB) |
| Charging IC | HIP6565ACV |
| Power IC(s) | HIP6565ACV (3-Phase PWM), HIP6602B, HIP6601B |
| Clock Generator | CY28410OXC (ICS954101) |
| Super I/O | SMSC DME1737 |
| VRM Controller | Intersil 6565 (HIP6565ACV) |
| VRM Phase | 3-Phase |
| Expansion Slots | PCI 2.3 Slot x2, PCI Slot x1 / Riser Card |
| Storage Interfaces | IDE Primary (UltraDMA33/66/100), SATA x2 |
| USB Ports | USB Port 0~7 |
| Audio Interface | AC97 |
| LPC Super I/O | SMSC DME1737 |
| Fan Control | SMSC DME1737 |
| TPM | TPM |
| Brand | MSI |
| Revision | 200 |
| Date | 星期四, 八月 11, 2005 |
| LAN IC | [URL="https://dr-bios.com/components/lan-ic/82547gi/"]INTEL 82547GI LAN-CSA[/URL] / [URL="https://dr-bios.com/components/lan-ic/82541gi/"]INTEL 82541GI LAN[/URL] |
| Brand | MSI (Micro-Star Int'l Co., Ltd.) |
| Model | MS-9149 |
| Revision | 200 |
| Date | 2004/02/21 |
| Graphics Architecture | ATI RAGE XL |
| Audio Codec | Not explicitly present in source |
| BIOS / SPI Flash | FWH |
| Charging IC | Not explicitly present in source |
| Power IC(s) | Intersil 6556B |
| LAN IC | [URL="https://dr-bios.com/components/lan-ic/82547gi/"]Intel 82547GI LAN-CSA[/URL], [URL="https://dr-bios.com/components/lan-ic/82541gi/"]Intel 82541GI LAN[/URL] |
| WiFi / WLAN IC | Not explicitly present in source |
| HDMI Level Shifter | Not explicitly present in source |
| Card Reader IC | Not explicitly present in source |
| USB Hub IC | Not explicitly present in source |
| Storage Controller | [URL="https://dr-bios.com/components/storage-controller/promise-pdc20378/"]PROMISE/PDC20378 SATA Controller[/URL] |
| Form Factor | ATX (12"*9.6") |
| Document Number | MS-9149 |
| Brand | MSI |
| Model | MS-9149 |
| Revision | 200 |
| Date | 星期二, 九月 06, 2005 |
| CPU Platform | Intel Canterwood-ES / ICH-HR Chipset |
| LAN IC | [URL="https://dr-bios.com/components/lan-ic/82547gi/"]INTEL 82547GI LAN-CSA[/URL], [URL="https://dr-bios.com/components/lan-ic/82541gi/"]INTEL 82541GI LAN[/URL] |
| Clock Generator | ck409-clk-gen/"]CK409 Clk Gen.[/URL] |
MS-9149
Pentium 4 478
ATI Rage XL
ATI VGA
NS/PC87366
ADT7463
6556B
VRM10 - INTERSIL 6556B
DDR
ECC
82541EI
82547EI
82540EM
PROMISE/PDC20378
ADT7463
NS/PC87366
Super I/O
NS/87431M MINI BMC
BMC
CK409
PROMISE/PDC20378
Storage Controller
ADT7463
6556B
ADT7463
ADT7463
82541GI
82547GI
NS/87431M
BMC
Canterwood
PCI32 VGA
800MHZ FSB
Northwood
Prescott
82540EM
82547GI LAN-CSA
82541GI LAN
PROMISE/PDC20378 SATA CONTROLLER
82541GI
NS/87431M MINI BMC
MS-7149N1
LGA775
Intel Prescott
ICH6
915GV
Intel Grantsdale GV
DME1737
1981B
BCM5788
HIP6565ACV
HIP6565ACV
HIP6601B
HIP6602B
CY28410OXC
DME1737
Super I/O
6565
DME1737
Storage Controller
Ich-hr
CK409 CLK GEN
MS-9149
Pentium 4 478
ATI Rage XL
ATI VGA
NS/PC87366
ADT7463
6556B
DDR
ECC
82541EI
82547EI
82540EM
PROMISE/PDC20378
ADT7463
NS/PC87366
Super I/O
NS/87431M MINI BMC
BMC
CK409
PROMISE/PDC20378
Storage Controller
ADT7463
6556B
ADT7463
ADT7463
82541GI
82547GI
NS/87431M
BMC
Canterwood
PCI32 VGA
800MHZ FSB
Northwood
Prescott
82540EM
82547GI LAN-CSA
82541GI LAN
82541GI
NS/87431M MINI BMC
MS-7149N1
LGA775
Intel Prescott
ICH6
915GV
Intel Grantsdale GV
DME1737
1981B
BCM5788
HIP6565ACV
HIP6565ACV
HIP6601B
HIP6602B
CY28410OXC
DME1737
Super I/O
6565
DME1737
Storage Controller
Ich-hr
CK409 CLK GEN
