msi ms-5650 56508 rev 0a
This Micro-Star International MS-5650 motherboard, dated November 22, 2007, utilizes a bq24030 charging IC within a dedicated Charger / Battery Detector architecture. The power block design includes multiple voltage rails such as VDD_SYS, VDD_IO, VDD_MCU, and VDD_CORE, with various buck converters and LDOs generating 3.3V, 1.8V, 1.2V, and 3.0V supplies. The system power management is controlled by signals including SYS_ON, CORE_ON, and PRE_CTL, with specific power domains for components like USB, SD/MMC, Bluetooth, GPS, and a Finger Print Sensor. The board also features a Centrality MCU for system control, with connections for reset and interrupt signals.
Q: What charging IC is used on this MS-5650 motherboard?
A: The charging IC is a bq24030, part of the Charger / Battery Detector architecture.
Q: What is the board number and date of this schematic?
A: The board number is MS-5650, and the schematic is dated Thursday, November 22, 2007.
| Brand | Micro-Star International Co., LTD. |
| Model | MS-5650 |
| Motherboard Manufacturer | Micro-Star International Co., LTD. |
| Board Number | MS-5650 |
| Date | Thursday, November 22, 2007 |
| Charging IC | bq24030 |
| Charger Architecture | Charger / Battery Detector |
