acer aspire 5630_5650_5680 compal_la-2922p_rev1.0 schematic
acer aspire 5630_5650_5680=1=compal_la-2922p_rev1.0.pdf
This Compal HBL50 motherboard, documented under board number LA-2922P and document number 401454A revision 1.0 dated 2006-09-05, is built around the Intel Yonah processor platform paired with the Intel 945GM/945PM chipset and ICH7-M southbridge. Graphics processing is handled by an nVidia G72MV (NP7M-SE) GPU with 64/128MB VRAM. System management is controlled by an ENE KB910Q EC/KBC. Audio is provided by an ALC883 codec, and networking by a BCM4401E LAN controller. The memory subsystem supports dual-channel DDRII via two 200-pin DDRII SO-DIMM slots.
Q: What is the board number and document number for this Compal HBL50 motherboard?
A: The board number is LA-2922P, and the document number is 401454A revision 1.0.
A: The EC/KBC is an ENE KB910Q.
A: The GPU is an nVidia G72MV (NP7M-SE) with 64/128MB VRAM.
Q: What memory architecture does this motherboard support?
A: It supports dual-channel DDRII memory via two 200-pin DDRII SO-DIMM slots.
| Model | HBL50 |
| Board Number | LA-2922P |
| Date | 2006-09-05 |
| Document Number | 401454A |
| CPU Platform | Intel Yonah |
| PCH / Southbridge | Intel ICH7-M |
| GPU Type | nVidia G72MV ([URL="https://dr-bios.com/components/graphics-models/np7m-se/"]NP7M-SE)[/URL] |
| EC / KBC | ENE KB910Q |
| Audio Codec | ALC883 |
| LAN IC | BCM4401E |
| RAM Type | DDRII |
| RAM Quantity / Slots | 200pin DDRII-SO-DIMM X2 |
