Schematic acer aspire 5630 5650 5680 compal la-2921p rev4.0 schematic
acer aspire 5630_5650_5680 compal_la-2921p_rev4.0 schematic
acer aspire 5630_5650_5680=1=compal_la-2921p_rev4.0.pdf
BrandCompal
ModelHBL50
Board NumberLA-2921P
Revision4.0
Date2006-10-04
CPU PlatformIntel Yonah Processor
PCH / SouthbridgeIntel ICH7-M
GPU TypenVidia G73M/(72M)/72MV
Graphics ArchitecturenVidia G73M/G72MV/NB7P-SE
EC / KBCENE KB910Q
Audio CodecALC883
BIOS / SPI FlashBIOS
LAN ICBCM4401E
WiFi / WLAN ICVT6311S
RAM TypeDDRII
RAM ArchitectureDual Channel
RAM Quantity / Slots200pin DDRII-SO-DIMM X2
Card Reader IC388SA8040_QFN64
USB Hub ICENE CB714
Charging ICF75383M
Power IC(s)DC/DC Interface CKT.
Thermal SensorSMsC LPC47N207FIR
HDMI Level ShifterCH7307CSD
Document Number401398HS
The Compal HBL50 LA-2921P motherboard, documented under revision 4.0 dated 2006-10-04, is built around the Intel Yonah processor platform with a 945GM/945PM chipset and ICH7-M southbridge. Graphics processing is handled by an nVidia G73M/G72MV/NB7P-SE GPU with 64/128/256MB VRAM. System memory consists of dual-channel DDRII via two 200-pin SO-DIMM slots supporting 400/533MHz. The embedded controller is an ENE KB910Q, and the audio codec is an ALC883. Networking is provided by a BCM4401E LAN controller and a VT6311S WLAN module. The board includes an ENE CB714 USB hub controller, a CH7307CSD HDMI level shifter, and a 388SA8040_QFN64 card reader controller. Power management is handled by a DC/DC interface circuit with an F75383M charging IC, and thermal monitoring is managed by an SMsC LPC47N207FIR sensor.
A: The embedded controller is an ENE KB910Q.
A: The audio codec is an ALC883.
Q: What LAN and WLAN controllers are used on this motherboard?
A: The LAN controller is a BCM4401E, and the WLAN controller is a VT6311S.
A: The board supports dual-channel DDRII memory via two 200-pin SO-DIMM slots.
Q: What GPU is used on this motherboard?
A: The GPU is an nVidia G73M/G72MV/NB7P-SE with 64/128/256MB VRAM.
  • Acer Aspire 5630_5650_5680=1=compal_la-2921p_Rev4.0.zip
