hp envy sleekbook 6 la-8662p rev-0.6 lotus 0307a uma k 1
This Compal LA-8551P Rev 0.1 Lotus motherboard schematic, dated 2011/10/27, details a platform built around an Intel Ivy Bridge ULV processor paired with the Panther Point PCH. The board supports up to two DDR3-SO-DIMM modules in a dual-channel configuration. System management is handled by an ENE KB932 EC/KBC with a dedicated 256kB EC ROM. The audio subsystem utilizes an IDT 92HD91 High Definition Audio codec. Integrated networking and media reading are provided by a single RTL8411 controller. The discrete graphics solution is an AMD Thames-XT GPU with 128-bit memory interface and eight DDRIII VRAM chips. The BIOS is stored across a 4MB plus 2MB SPI ROM configuration. A TPM 1.2 module, model SLB9635/9656, is also present on the board.
A: The board number is LA-8551P and the project code is Lotus.
A: The EC/KBC is an ENE KB932 with a dedicated 256kB EC ROM.
Q: What is the BIOS SPI ROM configuration?
A: The BIOS is stored on a 4MB plus 2MB SPI ROM.
Q: What discrete GPU is used on this motherboard?
A: The discrete GPU is an AMD Thames-XT with 128-bit memory interface and eight DDRIII VRAM chips.
Q: What is the audio codec and LAN/card reader controller?
A: The audio codec is an IDT 92HD91, and the LAN and card reader functions are combined in a single RTL8411 controller.
| Project Code | Lotus |
| Board Number | LA-8551P |
| Revision | 0.1 |
| Date | 2011/10/27 |
| CPU Platform | Intel Ivy Bridge ULV Processor with DDRIII + Panther Point |
| EC / KBC | ENE KB932 |
| EC Flash / ROM | 256kB |
| Audio Codec | IDT 92HD91 |
| BIOS / SPI Flash | 4MB + 2MB |
| RAM Type | DDR3-SO-DIMM |
| LAN IC | RTL8411 |
| Card Reader IC | RTL8411 |
| GPU Type | AMD Thames-XT |
| Graphics Architecture | 128Bit 128Mx16 VRAM x8pcs DDRIII |
| PCH / Southbridge | Panther Point |
| TPM | SLB9635/9656 |
