HP ENVY SleekBook 6 Compal LA-8731P QAU51 Lotus AMD Comal REV 0.1 Schematic
This Compal LA-8731P revision 0.1 motherboard, dated December 27, 2011, is built around an AMD APU FS1R2 platform paired with an AMD Hudson M2/M3 Fusion Controller Hub. Graphics processing is handled by an ATI Whistler/Seymour/Granville discrete GPU. The embedded controller is an ENE KB930, and system audio is managed by a Realtek ALC271X codec. Power management and charging are controlled by a Texas Instruments BQ24725RGRR charger IC. The board supports two DDRIII SODIMM memory slots and integrates a Broadcom BCM57785 LAN controller. The power delivery chart details multiple voltage rails including CPU core, NB core, GPU core, and memory voltages, with specific current ratings for each subsystem.
| Board Number | LA-8731P |
| Revision | 0.1 |
| Date | Tuesday, December 27, 2011 |
| CPU Platform | AMD APU FS1R2 |
| PCH / Southbridge | AMD Hudson M2/M3 |
| GPU Type | ATI Whistler/Seymour/Granville |
| EC / KBC | ENE KB930 |
| Audio Codec | ALC271X |
| Charging IC | BQ24725RGRR |
| RAM Type | DDRIII SODIMM |
| RAM Quantity / Slots | X2 |
| LAN IC | BCM57785 |
