hp dv6 6000 flex h510ua1 hpmh-40gab6300-d schematic
hp dv6 6000=1=flex h510ua1 hpmh-40gab6300-d.pdf
This HP MH-10 motherboard, documented under project code HPMH-40GAB6300-DD with document number H510UA1 revision 1 dated December 30, 2010, is built on the AMD Danube platform featuring an AMD RS880M North Bridge and AMD SB820M South Bridge. The graphics subsystem uses an ATI dGPU with Muxless Hybrid architecture supporting either a Seymour 64bit 15W or Whistler 128bit 25W GPU, with specific chip numbers HPMH-10-0020000049G for Seymour XT and HPMH-10-0020000050G for Whistler Pro. System memory consists of DDR3-SODIMM modules operating at DDR III 1066/1333 MHz. The embedded controller is an ITE ITE8518, and the audio codec is an IDT92HD80TA. Networking is handled by a Realtek RTL8111E-VB-GR Gigabit LAN controller, with wireless connectivity via a WLAN Half MINI-CARD slot. The board includes a Realtek RTS5209 card reader, a TI TUSB7320 USB 3.0 hub controller, and an SPI BIOS flash for firmware storage.
Q: What is the exact project code and document number for this motherboard?
A: The project code is HPMH-40GAB6300-DD and the document number is H510UA1, revision 1, dated December 30, 2010.
A: The embedded controller is an ITE ITE8518.
| Brand | HP |
| Model | MH-10 |
| Project Code | HPMH-40GAB6300-DD |
| Document Number | H510UA1 |
| Revision | 1 |
| Date | Thursday, December 30, 2010 |
| CPU Platform | AMD Danube |
| CPU Model | Dual/ Single Core |
| North Bridge | AMD RS880M |
| South Bridge | AMD SB820M |
| GPU Type | ATI dGPU with Muxless Seymour/ Whistler |
| Graphics Architecture | Muxless Hybrid: Seymour 64bit 15W + DDR3 x4 / Whistler 128bit 25W + DDR3 x8 |
| EC / KBC | ITE ITE8518 |
| Audio Codec | IDT92HD80TA |
| BIOS / SPI Flash | SPI BIOS |
| Charging IC | BATT CHARGER |
| RAM Type | DDR3-SODIMM |
| RAM Architecture | DDR III 1066/ 1333MHZ |
| LAN IC | Realtek RTL8111E-VB-GR |
| WiFi / WLAN IC | WLAN Half MINI-CARD |
| Card Reader IC | Realtek RTS5209 |
| USB Hub IC | TI TUSB7320 |
| dGPU Chip Number | Seymour XT: HPMH-10-0020000049G / Whistler Pro: HPMH-10-0020000050G |
| dGPU to UMA Conversion Support | Muxless Hybrid |
| Power IC(s) | dGPU VCORE |
| Thermal Sensor | ST Micro HP3D |
| HDMI Level Shifter | HDMI |
HPMH-40GAB6300-DD
Danube
Dual/ Single Core
RS880M
Northbridge / MCH
SB820M
Whistler
IT8518
IDT92HD80TA
RTL8111E-VB-GR
RTS5209
TUSB7320
HPMH-10-0020000050G
SEYMOUR XT: HPMH-10-0020000049G
SEYMOUR XT: HPMH-10-WHISTLER
ST MICRO HP3D
HPMH-40GAB6300-DD
Danube
Dual/ Single Core
RS880M
Northbridge / MCH
SB820M
Whistler
IT8518
IDT92HD80TA
RTL8111E-VB-GR
RTS5209
TUSB7320
HPMH-10-0020000050G
ST MICRO HP3D
