hp compaq 8510w inventec vb10_6050a2096501_rev a04 schematic
hp compaq 8510w=1=inventec vb10_6050a2096501_rev a04.pdf
This Inventec VB10 reference design, documented under board number PC3601 revision A04, is built around the Intel Merom 478 / Crestline CPU platform paired with the ICH8-M southbridge. The system memory architecture consists of two DDR2 SODIMM slots. Power management is handled by a multi-rail configuration including TPS51120, TPS51124, ADP3208, SC471, APL5913, G2998F11U, and G9338 regulators, with battery charging controlled by a BQ24703 IC. The embedded controller is a KBC1070. Audio is provided by an ALC861 codec, while wired networking is handled by an Intel 82566MM Gigabit LAN controller. Peripheral connectivity includes a RICOH_R5C853 card reader, an LPC355BGLF Super I/O, and an ICS9LPR355BGLF clock generator. The design also incorporates SPI flash, Mini Card, and docking connector support.
Q: What is the board number and revision for this Inventec VB10 platform?
A: The board number is PC3601, revision A04, documented under Inventec document number CSA3643.
A: The embedded controller is a KBC1070.
A: The battery charging IC is a BQ24703.
Q: What is the memory architecture on this motherboard?
A: The system uses two DDR2 SODIMM slots.
| Motherboard Manufacturer | Inventec |
| Project Code | VB10 |
| Board Number | PC3601 |
| Revision | A04 |
| Date | 22-May-2007 |
| Document Number | CSA3643 |
| CPU Platform | Merom 478 / Crestline |
| PCH / Southbridge | ICH8-M |
| EC / KBC | KBC1070 |
| Audio Codec | ALC861 |
| Charging IC | BQ24703 |
| Power IC(s) | TPS51120, TPS51124, ADP3208, SC471, APL5913, G2998F11U, G9338 |
| RAM Type | DDR2 |
| LAN IC | Intel 82566MM |
| Card Reader IC | RICOH_R5C853 |
| Super I/O | LPC355BGLF |
| Clock Generator | ICS9LPR355BGLF |
VB10
PC3601
Crestline
Merom
ICH8
KBC1070
ALC861
BQ24703
ADP3208
APL5913
G2998F11U
G9338
SC471
TPS51120
TPS51124
82566MM
RICOH_R5C853
LPC355BGLF
Super I/O
ICS9LPR355BGLF
VB10
PC3601
Crestline
Merom
ICH8
KBC1070
ALC861
BQ24703
ADP3208
APL5913
G2998F11U
G9338
SC471
TPS51120
TPS51124
82566MM
RICOH_R5C853
LPC355BGLF
Super I/O
ICS9LPR355BGLF
