Schematic hp 15cru-6050a2548201-mb-a01 pv 20121206 schematic
hp 15cru-6050a2548201-mb-a01 pv 20121206 1
BrandSAMSUNG / MICRON
Motherboard ManufacturerINVENTEC
Project CodeX012
Board Number1310A2548201A01
RevisionB
Date21-OCT-2002
CPU PlatformIVY BRIDGE
CPU SocketSOCKET RPGA 989
PCH / SouthbridgeHM77
EC / KBCITE IT8527
Audio CodecIDT92HD91
BIOS / SPI Flash8MB SPI ROM
Charging ICBQ24728
Charger ArchitectureAC CHARGER
Power IC(s)TPS51216RUK, TPS51219RTE, TPS51650RSLR, TPS51123RGER, RT8068AZQW, TPS51461RGER
RAM TypeDDR3L SO-DIMM
RAM ArchitectureDDR3 1333/1600 MAX 8GB
RAM Quantity / Slots2
Card Reader ICREALTEK_RTS5239
LAN ICRLT8161GSH-CG
WiFi / WLAN ICPANTHER WLAN + BT MINI CARD
HDMI Level ShifterRTJR
GPU Typeuma/"]CR-UMA[/URL]
Graphics ArchitectureUMA
Thermal SensorNUVO_NCT7717U_SOT23
Audio AmplifierTI_TPA3111D1, TI_TPA2012D2, TI_TPA6130A2
USB Hub ICRTJL
Document Number584X01
This INVENTEC motherboard, project code X012, board number 1310A2548201A01 revision B, is built around the IVY BRIDGE CPU platform using a SOCKET RPGA 989 and HM77 PCH. The system management is handled by an ITE IT8527 EC/KBC, with an 8MB SPI ROM for BIOS storage. Power management includes a BQ24728 AC charger and multiple voltage regulators including TPS51216RUK, TPS51219RTE, TPS51650RSLR, TPS51123RGER, RT8068AZQW, and TPS51461RGER. Memory configuration supports DDR3L SO-DIMM modules up to 8GB at 1333/1600 MHz across two slots. The audio subsystem features an IDT92HD91 codec with TI_TPA3111D1, TI_TPA2012D2, and TI_TPA6130A2 amplifiers. Networking is provided by a RLT8161GSH-CG LAN IC and PANTHER WLAN + BT MINI CARD. The board uses CR-UMA graphics architecture with no discrete GPU.
A: The ITE IT8527 is used as the embedded controller.
A: The board uses an 8MB SPI ROM for BIOS storage.
Q: What is the charging architecture?
A: The board uses a BQ24728 AC charger.
Q: What memory configuration does this board support?
A: It supports DDR3L SO-DIMM modules, up to 8GB maximum at 1333/1600 MHz, across two slots.
  • HP=1=15CRU-6050A2548201-MB-A01_PV_20121206.pdf
