Gigabyte GA-X79-UP4 Schematic
The Gigabyte GA-X79-UP4 motherboard, revision 1.1, is built around the Intel LGA2011 CPU platform and utilizes a PCH southbridge. The system is powered by a combination of IR3570, IR3567, and RT8120 power ICs. Memory support includes DDR III across four channels: A, B, C, and D. The embedded controller is an ITE 8728 LPC I/O. Audio is handled by the Realtek ALC898 codec. Networking is provided by an Intel 82579V Gigabit LAN controller. Storage connectivity includes Marvell 9172 SATA 3.0 controllers. USB 3.0 support is managed by FL1009 hub controllers. The board features a Dual BIOS configuration for firmware redundancy.
Q: What is the board number and revision for this Gigabyte motherboard?
A: The board is the Gigabyte GA-X79-UP4, revision 1.1, with document number 9MX79UP4-00-11A.
A: The embedded controller is an ITE 8728 LPC I/O.
A: The audio codec is a Realtek ALC898.
A: The LAN controller is an Intel 82579V.
Reuse permitted only with source attribution.
| Brand | Gigabyte |
| Model | GA-X79-UP4 |
| Revision | 1.1 |
| Date | Friday, February 01, 2013 |
| Document Number | 9MX79UP4-00-11A |
| CPU Platform | Intel LGA2011 |
| PCH / Southbridge | PCH |
| EC / KBC | ITE 8728 |
| Audio Codec | ALC898 |
| BIOS / SPI Flash | Dual BIOS |
| Charging IC | IR3570 |
| Power IC(s) | IR3567, RT8120 |
| RAM Type | DDR III |
| RAM Architecture | Channel A, Channel B, Channel C, Channel D |
| LAN IC | Intel 82579V |
| Card Reader IC | Marvell 9172 |
| USB Hub IC | FL1009 |
