Gigabyte GA-Z270N-GAMING Schematic
The Gigabyte GA-Z270N-Gaming 5 motherboard, revision 1.0, dated January 18, 2017, is built on the Intel LGA1151 platform supporting Skylake and Kaby Lake processors with a Z1270/H270 PCH. It features dual-channel DDR4 memory across two DIMM slots. The system is managed by an ITE 8686 LPC I/O controller, with audio handled by a Realtek ALC1220 codec and networking by an Intel i219V LAN controller. Power regulation includes an IR35201 PWM for VCORE and VCCGT, alongside RT8120 and RT8068A regulators. USB 3.1 connectivity is provided via an ASM2142 hub, while display output supports HDMI and DP interfaces. The board also includes an M.2 WiFi slot, NCT3933 thermal monitoring, and TI HD3SS3212 and TUSB321_B for GPU switching.
Q: What EC/KBC controller is used on the GA-Z270N-Gaming 5?
A: The motherboard uses an ITE 8686 LPC I/O controller.
Q: What audio codec is integrated on this motherboard?
A: The audio codec is a Realtek ALC1220.
Q: What is the LAN controller on the GA-Z270N-Gaming 5?
A: The LAN controller is an Intel i219V.
Q: What power management ICs are used for VCORE and VCCGT?
A: The IR35201 PWM is used for VCORE and VCCGT regulation.
| Brand | Gigabyte |
| Model | GA-Z270N-Gaming 5 |
| Document Number | Custom |
| Date | Wednesday, January 18, 2017 |
| CPU Platform | Intel LGA1151 (Skylake+KBL) |
| PCH / Southbridge | Z1270/H270 |
| EC / KBC | ITE 8686 LPC I/O |
| Audio Codec | Realtek ALC1220 |
| LAN IC | Intel i219V |
| WiFi / WLAN IC | M.2 WiFi |
| Charging IC | IR35201 PWM-SMD VCORE+VCCGT |
| Power IC(s) | RT8120_PCH, RT8120_DDR_CHOKE-IRON-2L, RT8068A_VPP_25V |
| USB Hub IC | ASM2142 USB31 |
| HDMI Level Shifter | HDMI, DP |
| Card Reader IC | NCT3933 |
| Thermal Sensor | NTC MAP |
| Graphics Architecture | MVP 8 |
| dGPU Chip Number | TI HD3SS3212&TUSB321_B |
Skylake
H270
8686 LPC I/O
ALC1220
I219V
IR35201
RT8068A_VPP_25V
RT8120_PCH
ASM2142 USB31
NCT3933
MVP 8
HD3SS3212&TUSB321_B
Skylake
H270
8686 LPC I/O
ALC1220
I219V
IR35201
RT8068A_VPP_25V
RT8120_PCH
ASM2142 USB31
NCT3933
MVP 8
HD3SS3212&TUSB321_B
