Gigabyte GA-H97-D3H R10 Schematic
The Gigabyte GA-H97-D3H motherboard, revision 1.0, is built on the Intel LGA1150 platform supporting Haswell and Haswell Refresh processors. The board utilizes the Intel Lynx Point PCH (Z97/H97) and features an ITE8620 EC/KBC. Audio is handled by a Realtek ALC1150 codec, while networking is provided by an Intel I217 LAN controller. The system memory architecture consists of four DDRIII DIMM slots. The board includes a SPI Dual BIOS configuration with 64M capacity. Power management is managed by an IR3564a Vcore PWM controller and IR3553+IR3598 DDR PWM, with overvoltage protection via an NCP3933 charging IC. Display outputs include DVI, HDMI, RGB, and DisplayPort. The board also integrates an ITE8892 PCI bridge for card reader functionality and USB 3.0 hub support.
Q: What BIOS configuration is used on the GA-H97-D3H?
A: The board uses a SPI Dual BIOS configuration with 64M capacity.
A: The board uses an ITE8620 EC/KBC controller.
Q: What audio codec is used on the GA-H97-D3H?
A: The audio codec is a Realtek ALC1150.
A: The board uses an Intel I217 LAN controller.
Q: What power management ICs are used on the GA-H97-D3H?
A: The board uses an IR3564a for Vcore PWM and IR3553+IR3598 for DDR PWM, with an NCP3933 for overvoltage protection.
| Model | GA-H97-D3H |
| Document Number | Custom |
| Date | Friday, February 28, 2014 |
| CPU Platform | Intel LGA1150 (Haswell/Haswell Refresh) |
| PCH / Southbridge | PCH (Lynx Point) (Z97/H97) |
| EC / KBC | ITE8620 |
| Audio Codec | Realtek ALC1150 |
| BIOS / SPI Flash | SPI Dual BIOS (64M) |
| LAN IC | Intel I217 LAN |
| RAM Architecture | DDRIII DIMM X 2, DDRIII DIMM X 2 |
| RAM Quantity / Slots | 4 |
| GPU Type | DVI, HDMI, Display, RGB |
| Graphics Architecture | Display |
| Charging IC | NCP3933 |
| Power IC(s) | IR3564a, IR3553+IR3598 |
| Card Reader IC | ITE8892 |
| USB Hub IC | USB 3.0 |
| WiFi / WLAN IC | Intel I217 LAN |
Haswell
H97
Z97
IT8620
ALC1150
I217 LAN
DISPLAY
DVI
HDMI
RGB
NCP3933
IR3553
IR3564A
IR3598
IT8892
Haswell
H97
Z97
IT8620
ALC1150
I217 LAN
DISPLAY
DVI
HDMI
RGB
NCP3933
IR3553
IR3564A
IR3598
IT8892
