gigabyte ga-h81m-d2ph_dr-bios.com gigabyte ga-h81m-d2ph_dr-bios.com schematic
gigabyte=ga-h81m-d2ph.pdf
The Gigabyte GA-H81M-DS2 Revision 3.0 motherboard, documented August 19, 2014, is built around the Intel LGA1150 CPU platform paired with the Intel H81 PCH. The board utilizes an ITE8620 LPC I/O controller for EC/KBC, HWM, fan control, and thermal sensor functions. Audio is handled by a Realtek ALC887 codec, while networking is provided by a Realtek RTL8111G LAN IC. The board supports DDRIII memory across two DIMM slots via a DDRIII BUS architecture. Graphics output is provided through an RGB Display interface driven by the integrated Intel LGA1150 GPU. Power regulation includes an ISL95812 VRIN PWM controller for VCORE and an RT8120 controller for DDR power. The board features a DUAL BIOS configuration and includes USB 3.0 hub support.
A: The ITE8620 LPC I/O controller is used for EC/KBC, HWM, fan control, and thermal sensor functions.
Q: What LAN IC is used on this motherboard?
A: The Realtek RTL8111G LAN IC is used, as documented in the BOM change history.
A: The Realtek ALC887 audio codec is used.
Q: What power controllers are used on this motherboard?
A: The ISL95812 VRIN PWM controller is used for VCORE, and the RT8120 controller is used for DDR power.
Q: Does this motherboard support DUAL BIOS?
A: Yes, the block diagram explicitly indicates a DUAL BIOS configuration.
| Brand | Gigabyte Technology |
| Model | GA-H81M-DS2 |
| Motherboard Manufacturer | Gigabyte Technology |
| Board Number | 9MH81MDS2-00-30B |
| Revision | 3.0 |
| Date | Tuesday, August 19, 2014 |
| CPU Platform | Intel LGA1150 |
| PCH / Southbridge | H81 |
| EC / KBC | ITE8620 |
| Audio Codec | Realtek ALC887 |
| LAN IC | Realtek RTL8111G |
| RAM Quantity / Slots | DIMM X 2 |
| RAM Architecture | DDRIII BUS |
| GPU Type | Intel LGA1150 |
| Graphics Architecture | RGB Display |
| Charging IC | ISL95812 |
| Power IC(s) | ISL95812, RT8120_DDR POWER |
| USB Hub IC | USB 3.0 |
| WiFi / WLAN IC | Realtek RTL8111G |
| Card Reader IC | ITE8620 |
| Thermal Sensor | ITE8620 |
| BIOS / SPI Flash | DUAL BIOS |
9MH81MDS2-00-30B
LGA1150
H81
IT8620
ALC887
RTL8111G
LGA1150
RGB Display
ISL95812
ISL95812
RT8120_DDR POWER
IT8620
IT8620
9MH81MDS2-00-30B
LGA1150
H81
IT8620
ALC887
RTL8111G
LGA1150
RGB Display
ISL95812
ISL95812
RT8120_DDR POWER
IT8620
IT8620
