gigabyte ga-h81m-d3h_dr-bios.com gigabyte ga-h81m-d3h_dr-bios.com schematic
gigabyte=ga-h81m-d3h.pdf
The Gigabyte GA-H81M-D3H motherboard, revision 1.0, is built around the Intel LGA1150 CPU platform and PCH H81 chipset. It features dual BIOS with 32M capacity, an ITE8620 EC/KBC, and a Realtek ALC887 audio codec. The board supports DDRIII memory across two DIMM slots and integrates Realtek RTL8111F for LAN. Graphics output is handled via RGB, DVI, and HDMI interfaces. Power management includes ISL95812 and RT8120 ICs, while the ITE IT8892 manages card reader and HDMI level shifting functions.
Q: What BIOS configuration is used on this motherboard?
A: This motherboard uses a dual BIOS configuration with 32M capacity.
A: The motherboard uses an ITE8620 EC/KBC controller.
A: The motherboard uses a Realtek ALC887 audio codec.
A: The motherboard uses a Realtek RTL8111F LAN controller.
| Model | GA-H81M-D3H |
| Board Number | GA-H81M-D3H |
| Date | 2014/01/02 |
| CPU Platform | Intel LGA1150 |
| CPU Socket | LGA1150 |
| PCH / Southbridge | PCH (H81) |
| EC / KBC | ITE8620 |
| BIOS / SPI Flash | DUAL BIOS (32M) |
| LAN IC | Realtek RTL8111F |
| RAM Architecture | DDRIII DIMM X 2 |
| RAM Quantity / Slots | DDRIII DIMM X 2 |
| GPU Type | Intel LGA1150 |
| Graphics Architecture | RGB, DVI, HDMI |
| Charging IC | ISL95812 |
| Power IC(s) | ISL95812, RT8120 |
| Card Reader IC | ITE IT8892 |
| USB Hub IC | USB 3.0 |
| WiFi / WLAN IC | Realtek RTL8111F |
| HDMI Level Shifter | IT8892 |
