Gigabyte GA-B150M-Power-EC Rev 1.0 Schematic
The Gigabyte GA-B150M-Power-EC Rev 1.0 motherboard is built on the Intel LGA1151 platform with a PCH B150 southbridge. The system is managed by an ITE8628 EC/KBC, and audio is handled by a Realtek ALC887 codec. The board features a 64M SPI BIOS flash and includes a Realtek 8111G LAN controller. Memory architecture consists of two DDR4 DIMM slots. Graphics are supported by the Intel LGA1151 CPU with VRD12 architecture. Power regulation is managed by ISL95858_856 PWM and MOSFET stages for VCore and VCCGT, along with RT8237 and NCP3933 over-voltage protection components. The board includes an RTD2168 DP to VGA converter for HDMI level shifting, an IT8892 card reader and USB hub controller, and a Realtek 8111HS wireless module.
A: The motherboard uses an ITE8628 EC/KBC.
Q: What BIOS flash type is used?
A: The board uses a 64M SPI BIOS flash.
Q: What audio codec is present?
A: The audio codec is a Realtek ALC887.
Q: What LAN controller is used?
A: The LAN controller is a Realtek 8111G.
A: The board supports two DDR4 DIMM slots.
| Model | GA-B150M-Power-EC |
| Board Number | GA-B150M-Power-EC 1.0 |
| Date | Tuesday, November 24, 2015 |
| CPU Platform | Intel LGA1151 |
| PCH / Southbridge | PCH (B150) |
| EC / KBC | ITE8628 |
| BIOS / SPI Flash | SPI BIOS (64M) |
| LAN IC | Realtek 8111G |
| RAM Architecture | DDR4 DIMM X 1, DDR4 DIMM X 1 |
| Graphics Architecture | VRD12 |
| GPU Type | Intel LGA1151 |
| Charging IC | ISL95858_856 PWM, ISL95858_856 MOS_VCORE, ISL95858_856 MOS_VCCGT |
| Power IC(s) | RT8237_DDR_BEAD, RT8237_PCH-BEAD, NCP3933 OVER VOLTAGE |
| HDMI Level Shifter | RTD2168 - DP to VGA - IC |
| Card Reader IC | IT8892 |
| USB Hub IC | IT8892 |
| WiFi / WLAN IC | Realtek 8111HS |
| Document Number | Custom |
GA-B150M-POWER-EC 1.0
LGA1151
B150
IT8628
ALC887
VRD12
LGA1151
ISL95858_856
NCP3933
RTD2168 - DP TO VGA - IC
IT8892
IT8892
8111HS
LGA1151
B150
IT8628
ALC887
VRD12
LGA1151
ISL95858_856
NCP3933
IT8892
IT8892
8111HS
