Schematic Gigabyte GA-990XA-UD3 Rev 101 Schematic
BrandGigabyte
ModelGA-990XA-UD3
Motherboard ManufacturerGigabyte
Project CodeU98094-00
Board NumberGA-990XA-UD3
Revision1.01
DateFriday, April 29, 2011
CPU PlatformAMD AM3/AM3+
CPU SocketAM3 Socket
PCH / SouthbridgeSB950
GPU TypeATI NB
Graphics ArchitectureRD780 Core
EC / KBCIT8720 JX
Audio CodecALC892R
BIOS / SPI FlashDual-BIOS
Charging ICISL6329+6609
RAM TypeDDRIII
RAM ArchitectureUnbuffered DDRIII DIMM
RAM Quantity / Slots4
LAN ICRTL8111D
WiFi / WLAN ICRTL8111E
Card Reader ICJMB362
USB Hub ICNEC uPD720200
HDMI Level ShifterRTM880N-793
The Gigabyte GA-990XA-UD3 revision 1.01 motherboard is built on the AMD AM3/AM3+ platform with an ATI NB GPU and RD780 core graphics architecture. The system is powered by an SB950 southbridge and utilizes an ISL6329+6609 charging IC for core power management. Memory support includes four unbuffered DDRIII DIMM slots. The board features an IT8720 JX EC/KBC controller and a Dual-BIOS SPI flash configuration. Audio is handled by the ALC892R codec, while networking is provided by the RTL8111D and RTL8111E LAN/WiFi ICs. Additional I/O includes a JMB362 card reader, an NEC uPD720200 USB hub controller, and an RTM880N-793 HDMI level shifter. The board number is GA-990XA-UD3 with project code U98094-00, and the document date is April 29, 2011.
Q: What is the EC/KBC controller used on this motherboard?
A: The EC/KBC controller is the IT8720 JX.
A: The motherboard uses a Dual-BIOS SPI flash configuration.
A: The audio codec is the ALC892R.
Q: What is the charging IC architecture on this motherboard?
A: The charging IC is the ISL6329+6609.
  • Gigabyte GA-990XA-UD3 Rev 101 Schematic.pdf
