Schematic gigabyte ga-8ip775-g rev 1.01 schematic
BrandGIGABYTE
ModelGA-8IP775-G
Revision1.01
CPU PlatformIntel Pentium 4 (478)
PCH / SouthbridgeICH5
GPU TypeAGP 8X SLOT
Graphics ArchitectureSPRINGDALE-G/-PE/-P
EC / KBCITE 8712
Audio CodecAC '97 CODEC
BIOS / SPI FlashDUAL FWH
BIOS Flash Exact ModelSST 49LF002A REV.B
BIOS Flash Exact ModelPMC 2M REV.E
BIOS Flash Capacity2M
Charging ICICS952635
RAM TypeDDR SDRAM DIMM X 2
RAM ArchitectureCHANNEL A, CHANNEL B
RAM Quantity / Slots2
LAN ICMARVELL 88E8001
Card Reader ICTI TSB43AB23 (1394)
USB Hub ICTI TSB43AB23 (1394)
The Gigabyte GA-8IP775-G motherboard, revision 1.01, is built around the Intel Pentium 4 (478) CPU platform with an ICH5 southbridge and Springdale-G/-PE/-P graphics architecture supporting an AGP 8X slot. The system memory consists of two DDR SDRAM DIMM slots configured as Channel A and Channel B. The board utilizes a dual FWH BIOS configuration, with exact models including the SST 49LF002A REV.B and PMC 2M REV.E, each with a 2M capacity. The embedded controller is an ITE 8712, and the audio subsystem is based on an AC '97 CODEC. Networking is provided by a Marvell 88E8001 LAN IC, while a TI TSB43AB23 (1394) controller handles card reader and USB hub functions. The clock generator is an ICS952635.
A: The motherboard uses a dual FWH configuration with SST 49LF002A REV.B and PMC 2M REV.E, each with a 2M capacity.
A: The embedded controller is an ITE 8712.
A: The board supports two DDR SDRAM DIMM slots configured as Channel A and Channel B.
  • Gigabyte=GA-8IP775-G_Rev_1.01_DR-BIOS.COM.zip
