dell xps m1530 wistron dh3 hawke_a01_mb 07212_rev-2m schematic
dell xps m1530=1=wistron dh3 hawke_a01_mb 07212_rev-2m.pdf
This Wistron Corporation motherboard, project code 91.4W101.001 with board number 48.4W101.02M and PCB number 07212 revision -2, is designed around the Intel Mobile CPU Merom 4M platform with an ICH8-M southbridge. The system supports DDRII 533/667 memory across two slots, configured as DDRII 667 Channel A and Channel B. Graphics are handled by either an nVidia NB8P (256MB) or nVidia NB8M (128MB) GPU with GDDRIII 700MHz memory. The embedded controller is a Winbond WPC8763L, and the BIOS is stored on a 2MB Flash ROM. Power management is handled by a MAX8731A battery charger and multiple DC/DC converters including ISL6262A, TPS51100, TPS51120, TPS51117, and RT9018A. Audio is provided by a Sigmatel STAC 9228 codec, networking by a Marvell 88E8040 NIC, and card reading by a Ricoh R5C833 controller.
A: The embedded controller is a Winbond WPC8763L.
Q: What BIOS flash configuration is used?
A: The BIOS is stored on a 2MB Flash ROM.
Q: What charging IC is used?
A: The battery charger IC is a MAX8731A.
Q: What GPU options are available?
A: The motherboard supports either an nVidia NB8P (256MB) or nVidia NB8M (128MB) GPU with GDDRIII 700MHz memory.
| Project Code | 91.4W101.001 |
| Board Number | 48.4W101.02M |
| PCB Number | 07212 |
| Revision | -2 |
| Date | Friday, December 21, 2007 |
| CPU Platform | Intel Mobile CPU Merom 4M FSB:667 or 800 MHz |
| GPU Type | nVidia NB8P(256MB) / nVidia NB8M(128MB) |
| Graphics Architecture | GDDRIII 700MHz |
| EC / KBC | Winbond WPC8763L |
| Audio Codec | Sigmatel STAC 9228 |
| BIOS / SPI Flash | 2MB Flash ROM |
| Charging IC | MAX8731A |
| Charger Architecture | Battery Charger MAX8731A |
| Power IC(s) | ISL6262A, TPS51100, TPS51120, TPS51117, RT9018A |
| RAM Type | DDRII 533/667 |
| RAM Architecture | DDRII 667 Channel A / DDRII 667 Channel B |
| RAM Quantity / Slots | Slot 1, Slot 2 |
| Card Reader IC | Ricoh R5C833 |
| LAN IC | Marvell 88E8040 |
| HDMI Level Shifter | HDMI |
| Document Number | A3159 / A3259 |
91.4W101.001
48.4W101.02M
07212
Merom
ICH8
NB8M
NB8P
GDDRIII 700MHz
WPC8763L
STAC9228
MAX8731A
ISL6262A
RT9018A
TPS51100
TPS51117
TPS51120
RICOH R5C833
88E8040
91.4W101.001
48.4W101.02M
07212
Merom
ICH8
NB8M
NB8P
GDDRIII 700MHz
WPC8763L
STAC9228
MAX8731A
ISL6262A
RT9018A
TPS51100
TPS51117
TPS51120
RICOH R5C833
88E8040
