dell xps m1530 wistron dh3 hawke_07212_rev-2m schematic
dell xps m1530=1=wistron dh3 hawke_07212_rev-2m.pdf
This Wistron Corporation motherboard, project code 91.4W101.001 with board number 48.4W101.02M and PCB number 07212 revision -2, is designed for an Intel Mobile CPU Merom 4M platform with FSB 667 or 800 MHz. The platform utilizes an ICH8-M southbridge and supports DDRII 533/667 memory across two slots, organized as DDRII 667 Channel A and Channel B. Graphics are handled by either an nVidia NB8P (256MB) or NB8M (128MB) GPU with GDDRIII 700MHz memory. The system is managed by a Winbond WPC8763L EC/KBC and boots from a 2MB Flash ROM. Audio is provided by a Sigmatel STAC 9228 codec, networking by a Marvell 88E8040 NIC, and card reading by a Ricoh R5C833 controller. Power management includes a MAX8731A battery charger, ISL6262A CPU core regulator, and multiple TPS51120, TPS51117, and RT9018 DC/DC converters.
A: The motherboard uses a Winbond WPC8763L EC/KBC.
A: The motherboard uses a 2MB Flash ROM for BIOS storage.
Q: What charging IC is used?
A: The charging IC is a MAX8731A battery charger.
A: The board supports DDRII 533/667 memory across two slots, organized as DDRII 667 Channel A and Channel B.
| Project Code | 91.4W101.001 |
| Board Number | 48.4W101.02M |
| PCB Number | 07212 |
| Revision | -2 |
| Date | Thursday, November 22, 2007 |
| CPU Platform | Intel Mobile CPU Merom 4M FSB:667 or 800 MHz |
| GPU Type | nVidia NB8P(256MB) / nVidia NB8M(128MB) |
| Graphics Architecture | GDDRIII 700MHz |
| EC / KBC | Winbond WPC8763L |
| Audio Codec | Sigmatel STAC 9228 |
| BIOS / SPI Flash | 2MB Flash ROM |
| Charging IC | MAX8731A |
| Charger Architecture | BATTERY CHARGER |
| Power IC(s) | ISL6262A, TPS51100, TPS51120, TPS51117, RT9018 |
| RAM Type | DDRII 533/667 |
| RAM Architecture | DDRII 667 Channel A / DDRII 667 Channel B |
| RAM Quantity / Slots | Slot 1, Slot 2 |
| Card Reader IC | Ricoh R5C833 |
| LAN IC | Marvell 88E8040 |
| HDMI Level Shifter | HDMI |
| Document Number | A3158 / A3258 |
91.4W101.001
48.4W101.02M
07212
Merom
ICH8
NB8M
NB8P
GDDRIII 700MHz
WPC8763L
STAC9228
MAX8731A
ISL6262A
RT9018
TPS51100
TPS51117
TPS51120
RICOH R5C833
88E8040
91.4W101.001
48.4W101.02M
07212
Merom
ICH8
NB8M
NB8P
GDDRIII 700MHz
WPC8763L
STAC9228
MAX8731A
ISL6262A
RT9018
TPS51100
TPS51117
TPS51120
RICOH R5C833
88E8040
