dell xps m1530 wistron dh3 hawke_07212_sa schematic
dell xps m1530=1=wistron dh3 hawke_07212_sa.pdf
This Wistron Hawke-IntelSA motherboard, project code 91.4W101.001 with board number 48.4W101.0SA revision 07212-SA, is designed around an Intel Merom 4M CPU platform supporting FSB 667 or 800 MHz paired with an ICH8-M southbridge. Graphics are handled by either an nVidia NB8P (256MB) or NB8M (128MB) GPU with GDDRIII 700MHz memory. The system uses DDRII 533/667 RAM across two slots in Channel A and Channel B configuration. The embedded controller is a Winbond WPC8763L, and the audio codec is a Sigmatel STAC 9228. BIOS storage is provided by a 1MB Flash ROM. Power management is handled by a suite of ICs including ISL6262A for CPU core, TPS51120 for 3.3V/5V, TPS51100 for DDR_VREF, TPS51117 for 1.8V and VGA core, RT9018A for 1.5V and 1.25V rails, and a MAX8731A battery charger. Connectivity includes a Marvell 88E8040 10/100 NIC, Ricoh R5C833 card reader, and 802.11a/b/g wireless support.
A: The embedded controller is a Winbond WPC8763L.
Q: What BIOS flash configuration is used?
A: The motherboard uses a 1MB Flash ROM for BIOS storage.
Q: What charging IC is used?
A: The battery charger IC is an ISL6255.
Q: What are the power ICs on this board?
A: The power management ICs include ISL6262A (CPU core), TPS51120 (3.3V/5V), TPS51100 (DDR_VREF), TPS51117 (1.8V and VGA core), RT9018A (1.5V and 1.25V), and MAX8731A (charger).
| Project Code | 91.4W101.001 |
| Board Number | 48.4W101.0SA |
| Revision | 07212-SA |
| Date | Tuesday, May 08, 2007 |
| CPU Platform | Intel Merom 4M FSB:667 or 800 MHz |
| GPU Type | nVidia NB8P (256MB) / nVidia NB8M (128MB) |
| Graphics Architecture | GDDRIII 700MHz |
| EC / KBC | Winbond WPC8763L |
| Audio Codec | Sigmatel STAC 9228 |
| BIOS / SPI Flash | 1MB Flash ROM |
| Charging IC | ISL6255 |
| Charger Architecture | Battery Charger |
| Power IC(s) | ISL6262A, TPS51120, TPS51100, TPS51117, RT9018A, MAX8731A |
| RAM Type | DDRII 533/667 |
| RAM Architecture | Channel A / Channel B |
| Card Reader IC | Ricoh R5C833 |
| LAN IC | Marvell 88E8040 |
| Document Number | A3155 |
91.4W101.001
48.4W101.0SA
Merom
ICH8
NB8M
NB8P
GDDRIII 700MHz
WPC8763L
STAC9228
ISL6255
ISL6262A
MAX8731A
RT9018A
TPS51100
TPS51117
TPS51120
RICOH R5C833
88E8040
91.4W101.001
48.4W101.0SA
Merom
ICH8
NB8M
NB8P
GDDRIII 700MHz
WPC8763L
STAC9228
ISL6255
ISL6262A
MAX8731A
RT9018A
TPS51100
TPS51117
TPS51120
RICOH R5C833
88E8040
