dell xps m1530 wistron dh3 hawke_07212_revsc schematic
dell xps m1530=1=wistron dh3 hawke_07212_revsc.pdf
The Wistron Hawke-IntelSC motherboard, project code 91.4W101.001 with PCB P/N 48.4W101.0SC revision SC, is an Intel Mobile platform designed around the Merom 4M CPU with FSB 667/800 MHz and the ICH8-M southbridge. Graphics are handled by either an nVidia NB8P (256MB) or NB8M (128MB) GPU with GDDRIII 700MHz memory. System memory consists of two DDRII 533/667 slots configured as Channel A and Channel B. The embedded controller is a Winbond WPC8763L, and the BIOS is stored on a 2MB Flash ROM. Power management is managed by a suite of ICs including the ISL6262A for CPU core, TPS51120 for 3D3V/5V, TPS5117 for system rails, and a MAX8731A battery charger. Audio is provided by a Sigmatel STAC 9228 codec, networking by a Marvell 88E8040 10/100 NIC, and card reading by a Ricoh R5C833 controller.
A: The embedded controller is a Winbond WPC8763L.
Q: What BIOS IC is used on this motherboard?
A: The BIOS is stored on a 2MB Flash ROM.
A: The battery charger IC is a MAX8731A.
Q: What GPU options are available on this motherboard?
A: The motherboard supports either an nVidia NB8P (256MB) or nVidia NB8M (128MB) GPU with GDDRIII 700MHz memory.
| Model | Hawke-IntelSC |
| Project Code | 91.4W101.001 |
| Board Number | 48.4W101.0SC |
| Revision | SC |
| Date | Friday, August 17, 2007 |
| CPU Platform | Intel Mobile CPU Merom 4M FSB:667 or 800 MHz |
| GPU Type | nVidia NB8P(256MB) / nVidia NB8M(128MB) |
| Graphics Architecture | GDDRIII 700MHz |
| EC / KBC | Winbond WPC8763L |
| Audio Codec | Sigmatel STAC 9228 |
| BIOS / SPI Flash | 2MB Flash ROM |
| Charging IC | MAX8731A |
| Charger Architecture | BATTERY CHARGER |
| Power IC(s) | ISL6262A, TPS51100, TPS51120, TPS5117, RT9018, MAX8731A |
| RAM Type | DDRII 533/667 |
| RAM Architecture | DDRII 667 Channel A / DDRII 667 Channel B |
| RAM Quantity / Slots | Slot 1, Slot 2 |
| Card Reader IC | Ricoh R5C833 |
| LAN IC | Marvell 88E8040 |
| HDMI Level Shifter | MAX4411 |
91.4W101.001
48.4W101.0SC
Merom
ICH8
NB8M
NB8P
GDDRIII 700MHz
WPC8763L
STAC9228
MAX8731A
ISL6262A
MAX8731A
RT9018
TPS51100
TPS51120
TPS5117
RICOH R5C833
88E8040
MAX4411
91.4W101.001
48.4W101.0SC
Merom
ICH8
NB8M
NB8P
GDDRIII 700MHz
WPC8763L
STAC9228
MAX8731A
ISL6262A
MAX8731A
RT9018
TPS51100
TPS51120
TPS5117
RICOH R5C833
88E8040
MAX4411
