dell xps l502x quanta nimoy gm6b dis f3a 100902 1
The Quanta Computer GM6B3A is a motherboard revision 3A, dated August 28, 2010, supporting the Arrandale/Clarksfield CPU platform via an rPGA 989 socket. It features a dual graphics architecture with integrated Intel UMA and discrete Nvidia N11P-GE/GTS graphics. The system memory consists of two DDR3 SO-DIMM slots supporting dual-channel DDR3 800/1066/1333 at 1.5V. The embedded controller is an ITE8502, and the audio codec is an ALC665. The main BIOS is stored on an 8Mbyte SPI flash, while a separate 1Mbyte 17X8 flash is used for the EC. Power management is handled by a suite of regulators including the TPS51427A, RT8207A, HPA00835RTER, VT356, VT358, ADP3211, ADP3212, and MAX17007, with charging controlled by an ISL88731. Networking is provided by a Realtek RTL8111E-GR LAN controller, and the system includes a JMB389 card reader.
Q: What is the main BIOS flash configuration on this motherboard?
A: The main BIOS is stored on an 8Mbyte SPI flash.
Q: What EC/KBC controller is used on the Quanta GM6B3A?
A: The embedded controller is an ITE8502, with a dedicated 1Mbyte 17X8 flash.
Q: Does this motherboard support both integrated and discrete graphics?
A: Yes, it supports both Intel UMA and discrete Nvidia N11P-GE/GTS graphics.
A: The charging IC is an ISL88731.
| Brand | QUANTA COMPUTER |
| Model | GM6B3A |
| Motherboard Manufacturer | QUANTA COMPUTER |
| Board Number | GM6B3A |
| Revision | 3A |
| Date | Saturday, August 28, 2010 |
| CPU Platform | Arrandale/Clarksfield |
| CPU Socket | rPGA 989 |
| PCH / Southbridge | PCH |
| GPU Type | Discrete GFX nvidia PCIEx16 N11P-GE/GTS |
| Graphics Architecture | Intel UMA and Discrete GFX nvidia |
| EC / KBC | ITE8502 |
| Audio Codec | ALC665 |
| BIOS / SPI Flash | FLASH 8Mbytes SPI |
| BIOS Flash Capacity | 8Mbytes |
| EC Flash / ROM | FLASH 1Mbytes 17X8 |
| Charging IC | ISL88731 |
| Charger Architecture | AC/BAT |
| Power IC(s) | TPS51427A, RT8207A, HPA00835RTER, VT356, VT358, ADP3211, ADP3212, MAX17007 |
| RAM Type | DDR3 |
| RAM Architecture | Dual Channel DDR3 800/1066/1333 1.5V |
| Card Reader IC | JMB389 |
| LAN IC | RTL8111E-GR |
| WiFi / WLAN IC | MINI-CARD WLAN |
| HDMI Level Shifter | SN75DP139RGZR, SN75DP120 |
| Document Number | 1122334455667788AABBCCDD |
GM6B3A
Arrandale
Clarksfield
989
Discrete GFX nvidia PCIEx16 N11P-GTS
IT8502
ALC665
ISL88731
ADP3211
ADP3212
HPA00835RTER
MAX17007
RT8207A
TPS51427A
VT356
VT358
JMB389
RTL8111E-GR
SN75DP120
SN75DP139RGZR
GM6B3A
Arrandale
Clarksfield
989
IT8502
ALC665
ISL88731
ADP3211
ADP3212
HPA00835RTER
MAX17007
RT8207A
TPS51427A
VT356
VT358
JMB389
RTL8111E-GR
SN75DP120
SN75DP139RGZR
