dell xps l502x quanta gm6b dis d2b 100626 1
The Quanta Computer GM62B motherboard, revision 1A, dated June 24, 2010, supports Intel Arrandale/Clarksfield processors in an rPGA 989 socket. It features dual graphics architecture with both Intel UMA and discrete Nvidia N11P-GE/GTS graphics via PCI Express x16. The platform uses an Intel PCH and is equipped with an ITE8502 EC/KBC. System firmware is stored on an 8Mbyte SPI flash, with a separate 1Mbyte flash for the EC. Memory configuration includes two DDR3 SO-DIMM slots supporting dual-channel DDR3 800/1066/1333 at 1.5V. Power management is handled by a suite of regulators including TPS51427A, RT8207A, ADP3211, ADP3212, HPA00835RTER, VT356, VT358, and MAX17007, with an ISL88731 battery charger. The audio subsystem uses a Realtek ALC665 codec with MAX9736AEJ amplifiers. Networking is provided by a Realtek RTL8111E-GR LAN controller, and a JMB389 card reader is integrated. HDMI connectivity is supported via SN75DP139RGZR and SN75DP120 level shifters.
Q: What EC/KBC is used on the Quanta GM62B motherboard?
A: The motherboard uses an ITE8502 EC/KBC controller.
A: The BIOS SPI flash is 8Mbytes.
Q: Does this motherboard support both UMA and discrete graphics?
A: Yes, the Quanta GM62B supports both Intel UMA and discrete Nvidia N11P-GE/GTS
| Brand | QUANTA COMPUTER |
| Model | GM62B |
| Project Code | GM62B |
| Board Number | GM62B |
| Revision | 1A |
| Date | Thursday, June 24, 2010 |
| CPU Platform | Arrandale/Clarksfield |
| CPU Socket | rPGA 989 |
| PCH / Southbridge | Intel |
| GPU Type | Discrete GFX nvidia PCIEx16 N11P-GE/GTS |
| Graphics Architecture | UMA and Discrete GFX |
| dGPU Chip Number | N11P-GE/GTS |
| EC / KBC | ITE8502 |
| Audio Codec | ALC665 |
| BIOS / SPI Flash | 8Mbytes |
| BIOS Flash Capacity | 8Mbytes |
| EC Flash / ROM | 1Mbytes |
| Charging IC | ISL88731 |
| Charger Architecture | AC/BATT CHARGER |
| Power IC(s) | TPS51427A, RT8207A, ADP3211, ADP3212, HPA00835RTER, VT356, VT358, MAX17007 |
| RAM Architecture | Dual Channel DDR3 800/1066/1333 1.5V |
| Card Reader IC | JMB389 |
| LAN IC | RTL8111E-GR |
| WiFi / WLAN IC | MINI-CARD WLAN |
| HDMI Level Shifter | SN75DP139RGZR, SN75DP120 |
| Document Number | 1163 |
GM62B
GM62B
Arrandale
Clarksfield
989
Discrete GFX nvidia PCIEx16 N11P-GTS
N11P-GE
N11P-GTS
IT8502
ALC665
8MBYTES
1MBYTES
ISL88731
ADP3211
ADP3212
HPA00835RTER
MAX17007
RT8207A
TPS51427A
VT356
VT358
JMB389
RTL8111E-GR
SN75DP120
SN75DP139RGZR
GM62B
GM62B
Arrandale
Clarksfield
989
N11P-GE
N11P-GTS
IT8502
ALC665
8MBYTES
1MBYTES
ISL88731
ADP3211
ADP3212
HPA00835RTER
MAX17007
RT8207A
TPS51427A
VT356
VT358
JMB389
RTL8111E-GR
SN75DP120
SN75DP139RGZR
