dell latitude xt tablet pc e5400 parker mb a00 0814w r-1 1
The Wistron Parker-1 motherboard, project code 91.4S701.001 and board number 48.4S701.001, is designed for Intel Yonah or Merom ULV processors including models U1400, U1500, U7500, and U7600 with a 533MHz FSB. The platform utilizes an ATI SB600 southbridge with integrated ATI graphics supporting dual-channel DDR2 533/667MHz memory via a single 200-pin SODIMM socket. System management is handled by three SMSC controllers: MEC5025, ECE5021, and ECE1077. The BIOS is stored on a 2MB SPI flash. Audio is provided by a STAC 9205 Azalia codec. Networking capabilities include a BCM5756M Gigabit LAN controller and 802.11a/g/n wireless. Power management is handled by an ISL88731 battery charger and multiple DC/DC converters including ISL6236, MAX8778, ADP3207, TPS51100, and MAX8794. The board also features a TI 7402 card reader and an EMC4001 thermal sensor.
Q: What BIOS IC type is used on this motherboard?
A: The motherboard uses a 2MB SPI flash for BIOS storage.
Q: What EC/KBC controllers are used on this motherboard?
A: Three SMSC controllers are used: MEC5025, ECE5021, and ECE1077.
Q: What is the charging architecture on this motherboard?
A: The charging architecture uses an ISL88731 battery charger.
Q: What CPU models are supported on this platform?
A: The platform supports Intel Yonah or Merom ULV processors, specifically models U1400, U1500, U7500, and U7600.
| Project Code | 91.4S701.001 |
| Board Number | 48.4S701.001 |
| Revision | 06240-1 |
| Date | Tuesday, August 14, 2007 |
| Document Number | 12.1WXGA |
| CPU Platform | Yonah / Merom ULV |
| CPU Model | U1400, U1500, U7500, U7600 |
| PCH / Southbridge | SB600 |
| GPU Type | ATI Integrated Graphics |
| EC / KBC | SMSC MEC5025, SMSC ECE5021, SMSC ECE1077 |
| Audio Codec | STAC 9205 |
| BIOS / SPI Flash | SPI FLASH 2MB |
| Charging IC | ISL88731 |
| Charger Architecture | Battery Charger |
| Power IC(s) | ISL6236, MAX8778, ADP3207, TPS51100, MAX8794 |
| RAM Type | DDRII 533/667MHz |
| RAM Architecture | Unbuffered DDR2 SODIMM, Dual DDR2 Channel |
| RAM Quantity / Slots | 200-PIN DDR2 SODIMM |
| Card Reader IC | TI 7402 |
| LAN IC | BCM5756M |
| WiFi / WLAN IC | 802.11a/g/n |
| Thermal Sensor | EMC4001 |
91.4S701.001
48.4S701.001
Merom-ULV
Yonah
U1400
U1500
U7500
U7600
SB600
ECE1077
ECE5021
MEC5025
STAC9205
ISL88731
ADP3207
ISL6236
MAX8778
MAX8794
TPS51100
7402
BCM5756M
EMC4001
91.4S701.001
48.4S701.001
Merom-ULV
Yonah
U1400
U1500
U7500
U7600
SB600
ECE1077
ECE5021
MEC5025
STAC9205
ISL88731
ADP3207
ISL6236
MAX8778
MAX8794
TPS51100
7402
BCM5756M
EMC4001
